Home > In Car Electronics > Courtesy Light Switches On Rear Doors
shaggydog
Hi Guys,
I does anybody know how to fit Courtesy Light Switches to the middle and rear doors on an early defender?
I currently have the front ones factory fitted and have added a second light in the load area but was wandering if I can fit switches to my middle and rear doors so when loading and unloading in the dark is a bit easier.
Also does anybody know of any better switches as mine are like pin switches and often need a wiggle to work Rolling Eyes
Thank you in advance!
Dog
Post #303024 28th Jan 2014 10:50pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Use origional switched all you need is a live and a ground back to the pin 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #303049 29th Jan 2014 7:17am
Romadog
Seems like your switches are dirty or corroded. Take them out and clean the contacts and the screw hole
Post #303166 29th Jan 2014 5:32pm
shaggydog
Will give them a clean Thumbs Up
So all I have to do is add the new switches and a earth wire from the switch up to the earth wire connected to the lamp?
Post #303216 29th Jan 2014 7:59pm
I'm pretty sure that the switches are triggered by a small metal tab in the leading edge of each door. If yours has never had switches fitted then it would be worth checking if those tabs are there before making a start. Darren
Post #303258 29th Jan 2014 9:21pm
shaggydog
It has the switches fitted to the front doors but not the middle or rear, though the tabs are present Thumbs Up
The rear door will need a tab making up though that should take all of 5 minutes.
Post #303265 29th Jan 2014 9:32pm
