Home > Technical > noise
cord
United Kingdom 2005 Defender 90 Td5 CSW Java Black
noise
hi everybody
i have just purchased a 2005 swb 90 from a dealer in somerset [i live in birmingham]. it has developed a noise from the back end [metalic sound] when i move forward and when i move backward.because of the distance involved going back to the dealer i took it to garage by me [the mechanic has a disco himself so knows a thing or two],he checked all the bushes and said they were fine and said the noise seems to be coming from rear axle. i phoned the dealer and he said it sounds like a drive flange needs replacing ,so posted 2 to me to fit which i did. replaced left side first and checked for noise [still there] then replaced right side [still got noise] has anybody got any ideas? [mechanic checked the props said they were fine]
also went to work this morning come home and noticed a wheel center [on rear wheel] was mising, when i looked close i could see the rubber cup was missing on drive flange. i would say the cup blew off taking the wheel center with it, if i had put to much grease around shaft and in the cup could this have happened?
yours cordell
Post #30132 19th Apr 2010 5:18pm
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I have the same noise in my 2008 Puma. It is booked in with the dealer for next Tue, so will let you know what they find.
I, too, couldn't find any loose bushes, prop shaft bolts or A frame welding faults. Sounds like someone hitting the chassis with a screwdriver handle.
Austen. Rover 12 1935
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #30190 20th Apr 2010 6:23am
dgardel
Italy
99% bracke pads.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #30220 20th Apr 2010 11:34am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
You should be able to take it to any dealer - not just the one you bought it off.
If it's covered by warranty then any dealer can do it Thumbs Up
Embarassed just re-read your post. 2005 Banging Head sorry. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #30263 20th Apr 2010 2:53pm
cord
hi
sorry i forgot to mention i purchased it from a independent dealer ,with there own warranty. it means 140 miles there and the same back,then if i have to leave it there its the same again to pick it up Big Cry
cordell
Post #30277 20th Apr 2010 4:15pm
