![]() | Home > Td5 > Water ingress , but where? |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Pedal box to bulkhead may be leaking.
Or it may even be the windscreen frame to bulkhead seal leaking and the water running down. |
epictrail Member Since: 20 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Or the seals on the front air vents might need replacing.
PM me your email and I'll send you the Land_Rover_Defender_Water_Ingress_Manual.pdf" |
Jack77 Member Since: 13 Oct 2013 Location: London-Hertfordshire Posts: 56 ![]() ![]() ![]() |
I will have a look at all these things!
Email sent
To check if it's the screen that's leaking.....
Wait for a rainy day (shouldn't be too long ![]() Put some kitchen wiper on the dashtop so about an inch is going down the gap between the windscreen and the dash. Check that it's below the bottom of the windscreen and above the scuttle vents. If it gets wet it's the screen. ![]() |
This sounds like a plan1
