Home > Puma (Tdci) > A false slipping belt |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2109 |
Hi there
i like to know if someone had the same problem in the past. 1 week ago our Defender start to had a noise that we believe were the ancilliary belt. At this moment the 80.000 km check service was quite near, so we wait to make all together. The dealer check it and was agreed that the problem were the belt and they change it. But for their surprise (and mine also) during the road test the noise was still there Finally their localize the fault as a air leaking (that sound equal to a sliipery belt) in the turbo between a seal and the turbo admission. According to them is not a problem to have this leak and the work to locate the fault and repair it will be postponed until next week, so I can had my defender during the weekend. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
16th Apr 2010 11:29pm |
Things are getting worse
The problem is a seal in the turbo and they must to take out and open it (according to them the second one with the same problem) I can use it but the noise drives me crazy. Will be sorted on Thursday I hope As usual, they forgot to put the door window handle and they make a huge scratch in the fender and finally one of the mugguards flaps went off (a screw dissapear) Also during this morning (not quite cold) the engine loss power at the beginning. That was for 1-2 minutes and then goes OK. I didn't tried the jacking point again, but they made a huge correction there adding a plate to keep the tube in place ... Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
19th Apr 2010 2:24pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
hope it's sorted on Thursday then Ed 2.4 90 XS
19th Apr 2010 3:13pm |
