Home > Maintenance & Modifications > New loom for both headlight relay upgrade and add'l lights |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3646 |
For a minute there I thought I had wasted my time and money buying the dutch relay loom, however having just studied the drawings I concurr with ZeDefender that full current still appears to go throught the column switch despite there being a relay in the circuit. It appears the relay is just there to control the lighting systems logic DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
21st Jan 2014 8:40pm |
In any event, I measured the difference with the new loom - a 0.7 volt increase is good in anyone's money
*Edit* and if any existing relay was doing its job, the light switch wouldn't burst into flames Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
21st Jan 2014 8:44pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
Is the relay in the standard system to provide, stop power due to ignition position? So when ignition is off it cuts the headlights to sidelights only?
Andy |
21st Jan 2014 8:51pm |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
Yup
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
21st Jan 2014 8:55pm |
