Home > Puma (Tdci) > Fog Machine when using aircon
johnnyd
Hi All
Used the aircon by accident this morning, and on the M4 the fog seemed worse than usual, eventually i worked out the fog was on the inside as well as outside, is it normal for the aircon to create a lot of condensation inside the cabin ? Or have a bought a fog machine Wink
JD 2008 TDCi 2.4 XS CSW
Post #300814 21st Jan 2014 10:27am
Laurie
You heat the windscreen to demist it.
....need I say more? Rolling Eyes
Post #300815 21st Jan 2014 10:31am
johnnyd
I had worked that one out thanks Wink
The question was.....is it normal for the aircon to create a lot of condensation inside the cabin...... Rolling Eyes
Post #300816 21st Jan 2014 10:35am
jimbob7
Condensation gathers on the air-con matrix,the same condensation that stinks if it's left to stagnate,to remove condensation switch your air-con OFF and run the blowers for 5 minutes before switching off. Pov.spec,ftw. 2006, 110,TD5.
Post #300817 21st Jan 2014 10:36am
x-isle
Check that your aircon drain plug isn't sealed shut.
If any moisture removed by the Aircon can't drain, you end up heating it and causing steam, it also usually overflows into the passenger footwell when it gets too full.
You'll find it above the gearbox in the transmission tunnel.
You won't see it, but force your hand up over the gearbox into the space in the tunnel and you should find a teat, squeeze it and you'll open the seal and probably get drenched.
It was one of the reasons that we got rid of the Jag XK as it has a similar drain pipe. Only problem is, Jag decided to make it inaccessible unless you remove the gearbox! Rolling Eyes Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #300823 21st Jan 2014 10:50am
johnnyd
Many thanks for the info, can I get to this teat with it on the ground, or does it need elevating at all ? This may be the issue as a rather interesting smell occurs also, i thought it was just Bath smelling as I passed junction 18 Rolling with laughter
Post #300826 21st Jan 2014 10:58am
x-isle
Yes, you can get to it by lying underneath.
Plenty of space, but if it is sealed shut, be prepared to get a drenching! Smile Craig Rogers
2007 Puma 110 XS
Post #300827 21st Jan 2014 11:00am
