Home > Puma (Tdci) > Transfer Box or Clutch Failure?? |
The only way you are going to be able to tell where the clunk clack bang is coming from is by jacking up a wheel and turning it by hand, listening for scraping clunking noises. It may be neither the clutch nor the transferbox... Could be one of the differentials, or a UJ or indeed the transfer brake. Just remember to chock your wheels before jacking then release the transfer brake. Let us know how you get on.
20th Jan 2014 10:20am |
Whitewaitress Member Since: 26 Nov 2013 Location: Liverpool Posts: 47 |
Thanks Guy,
I will check the movement in the wheels, the noise sounds exaclty like that in this youtube video at around 16 and 40 seconds. The clatter and screech are very similar. Cheers, Rob |
20th Jan 2014 1:11pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Hi Rob
Have a read, not saying it is this but there have been a few with the same problem. http://www.defender2.net/forum/topic11955.html Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
20th Jan 2014 1:33pm |
If you cannot hear anything it would be a good idea to dump the oil from the axles first, then the transferbox and see what comes out. If something has gone then you should see chunks in the oil and the diff pan or transfer box. Open up the filler plug as well and shine a torch in there too, if the gears have eaten themsleves it will be very obvious. I suspect it is not the front diff as having had that go on my 2002 110 you know when it does.. rear wheels almost came off the ground when that seized up. This is what it looked like when I drained the oil and took the diff out; [URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL][URL=][/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
20th Jan 2014 1:55pm |
Cheers guys - not had chance yet to investigate any further, although one of the guys who works over the road from me seems to think its the splines on the main shaft that comes from the gearbox, and that they have worn with them not bein lubricated. He took a quick listen and came up with this diagnosis straight away.
I will keep you posted - fingers crossed the transfer box isn't another made of cheese! |
21st Jan 2014 12:42pm |
That was exactly the problem I had and posted in the link above. The shaft goes before the transfer box - hopefully !
Not uncommon. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
21st Jan 2014 1:18pm |
Cheers Bob - I did find your thread useful reading - I'm hoping that is the extent of the problem and nothing further!!
21st Jan 2014 2:59pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17355 |
If your failure was the adaptor shaft I doubt you'd have any drive at all.
I can say this with some confidence since I am writing this while waiting for the RAC to come to take me home after suffering an adaptor shaft failure. |
21st Jan 2014 5:23pm |
Quick update for those who have posted / read this thread:
Problem was the transfer box - the internals had shattered to bits - could have been caused by one fragment coming away from a cog or bearings failing. I'm not completely sure. I had hoped it would be a mainshaft but sadly it wasn't!! It's worrying that you could be plodding along anywhere in the world and something like this go 'bang' on you!! Thanks to all of your input guys!! |
16th Feb 2014 8:40pm |
