Home > Maintenance & Modifications > front swival recovery points!!!!!!!!!!
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i'm trying to fit a pair of the above and the circlip plyers i have just won't open the clip wide enough to fit it, i have try'd two pair of mole grips but even that won't quite do it and anyway i'm afrade i'll twised and break the clip, so any ideas that will get them on without me having to make up an oversized pair of circlip plyers, in brief 1.5mm thick circlip over a 38mm bar, and yes they are the ones that came supplyed so should be the right size, any ideas that don't involve cash greatfully recieved,
thanks mark.
Post #30044 18th Apr 2010 9:26am
Cibit
Can you not force it over the end and use a pipe or socket to push it into place?
I assume its the ones you push through from behind and secure it from the front with circlip? 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #30047 18th Apr 2010 9:57am
double cab happy
your right about the type, and with me and the wife on a pair of mole grips am still 1mm off Mad
Post #30049 18th Apr 2010 10:01am
double cab happy
all done now, what a pain in the arse, i think i got the wrong sized clip, but hay its on now well nearly just need that last little bit of travel for the circlip to seat so i'm of to find a big tree get a rope around it and pull a bit in the thing's.
Post #30052 18th Apr 2010 11:27am
