![]() | Home > Td5 > Disk Handbrake |
Is this the X-Brake? (Supplied by X-Eng) An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 ![]() |
To be 100% honest I am not sure as I had my garage source and fit it but from the brief time I spent adjusting it it looks very similar to what I just looked up now so I suspect so but can check when there is some light as the truck is now locked away in the garage. Defender 90 TD5 County - You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
If it's the X Eng the X will be profiled out of the protecting guard which protects the disk.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8165 ![]() ![]() ![]() |
you can adjust the throw of the arm on the caliper too, plus there are different mounting holes for the cable to attach to this arm, each adjusting the amount of pull required.
when new or with new pads they do seem to take a while to settle/bed in. you say it uses the whole range of the lever, but does it hold? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
I had both of those problems and resetting the lever cured both of them. If you download the x-eng disk brake instructions they have an explanation on how to do it.
I think basically your pads are sitting too far off the disk and your having to compensate with the cable - when really you need it to be on the arm, that way the pads can sit off the disk at rest (with no tension on the cable) - but will pull on firmer when you pull the lever. I'm happy to provide more info if needed. |
OK thanks for the tips have downloaded the x-eng manual and will get under the truck on the weekend to see what is going on it must be just needing a bit of tweaking to get adjusted correctly. Defender 90 TD5 County -
