Home > Maintenance & Modifications > Wiring Loom |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6105 |
Has everything... including (I think) all the correct colour factory cable...
15th Jan 2014 5:30pm |
DJ
If you've got filaments over 65W (classed as offroad) the switch light must only come on when the lights are physically illuminated, not when they are 'armed' (the switch is depressed but lights extinguished). Not sure about road legal filaments if the dash high beam lamp will suffice. Have you commenced the window replacements yet? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 18th Jan 2014 8:33pm. Edited 2 times in total |
18th Jan 2014 8:28pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
On, all the time, the button is in, and lamps ready for action California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
18th Jan 2014 8:29pm |
Cool, cheers all. I'm making a loom up for Walfy, so just wanted to check I got it the right way round.
K9F.... no, not yet, letting the foliage grow a bit more before I harvest it! |
18th Jan 2014 8:32pm |
The "gen" loom lights as above,, (95% sure) but they are for the standard LR supplied lamp kit so guess 55W California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
The blue wire goes all the way over to the dash, to pick up the main beam signal California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
18th Jan 2014 8:34pm |
It's unfortunately an MOT fail if the filaments are offroad classification and the switch doesn't illuminate when the lights are physically illuminated.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th Jan 2014 8:35pm |
^^^^ Yeah, I see that routing from the .pdf doc above.
We're just deciding whether to pull the binnacle apart to hook up to the main beam feed, or, as I'm making the loom up anyway, run another wire down to the front of the vehicle (along with the LED bar feed) and hook into the back of the LH headlight main beam feed from there. It's up to the vehicle owner. I'll let him decide |
18th Jan 2014 8:36pm |
18th Jan 2014 8:37pm |
Yet to see a tester take a aux lamp out to check the wattage during a test Mine are only candles, at 35W each California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
18th Jan 2014 9:20pm |
Are they those silly light bars? i was explaining to Mark how good old '80s KC's or CIBIE oscars are the way forward.
He wouldn't have it |
18th Jan 2014 9:25pm |
You know me better than that Jamie,
He just needs some bling !! plus, maybe the fact that he was "outshown" with his Lightforce by some 35W Hid's Personally, don't think the "silly light bars" suit the timeless line's of a Defender, but they work well Now a pair of KC's or Oscars California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
18th Jan 2014 9:43pm |
Most testers aren't stupid either......Quick glance would suffice Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th Jan 2014 9:48pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2666 |
Oi, you 2. Round lights belong in the 80's. Get with modern times.
Lightbar is fitted and I think it looks nice where I've fitted it. Tucked up under the top spar of the A bar. Works for me. No need for bling. Just a need for some decent light up front. I'd rather have poor lights than fail to climb a sandy slope off the beach. . It's just driving on flat sand I have issues with 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
18th Jan 2014 11:11pm |
