![]() | Home > In Car Electronics > Should the radio work with the ignition off (MY13 Puma)? |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 ![]() ![]() |
Hi Jim
my 08my 90 truck cab comes on with engine off and says on the display 1hour i assume its so you can have the radio on without draining the battery. this is a land rover head unit. Will check the 110 later which has the alpine head on ![]() steve |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 ![]() ![]() ![]() |
Thanks Steve!
I blew a fuse on the interior lights/radio earlier and i'm sure I could use the radio before I replaced the fuse. Just wondered if i'd blown anything else! |
Hi Jim
The radio does not work without ignition on with the Alpine head unit. steve |
Thanks Steve - just wanted to be sure!
Saved me checking ALL the remaining fuses ![]() |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
It does. Once you turn off the engine, so long as the key is in position 1 you can use the radio ![]() |
On the land rover head unit the key doesn't need to be in and you get an hour before it turns itself off.
I was trying with no key. ![]() |
That has been a common thing with Fords, another legacy of the Americans. They probably offloaded a couple of decades worth of stocks when they left
