Home > Technical > Grating from OSF Suspension- help?
CFB
I'm having trouble locating the cause of a grating noise from the OSF suspension on my 110. When it's articulating up into the arch there is a grating noise as if something is rubbing but I can't find any evidence of
this, also get a slight knock when cornering to the left (ie all weight towards OSF wheel).
My local mechanic thought it was the wheel bearing which had a bit of play but that's now been adjusted up and I still get the problem. The knock is much less pronounced but the grating is there. I initially thought maybe a
broken coil spring or knackered suspension bushes but it all looks OK.
Any ideas? Andy
Post #29039 5th Apr 2010 3:35pm
discocuzzy
CV Joint? You cannot teach stupid people to do clever things
Post #29054 5th Apr 2010 8:26pm
CFB
Dunno, don't they usually start clicking when you turn if they are failing? Andy
Post #29056 5th Apr 2010 8:43pm
discocuzzy
Could be drive flanges Andy or the half shafts Question You cannot teach stupid people to do clever things
Post #29057 5th Apr 2010 8:49pm
110SEB
If it's happening at full lock, then i'm thinking CV joint too.
Post #29059 5th Apr 2010 8:58pm
CFB
Grating occurs when wheels straight too but only when really articulating Andy
Post #29069 5th Apr 2010 9:34pm
110SEB
What tyres are you running? Are they rubbing on the arches? I'm sure you've already thought of this.
Post #29070 5th Apr 2010 9:36pm
CFB
265 75 16 on Freestyle alloys, it is baffling me Andy
Post #29075 5th Apr 2010 9:56pm
110SEB
Hmm, hardly monster truck rubber. Odd one.
Post #29081 5th Apr 2010 10:31pm
discocuzzy
I recon drive flanges or half shafts mate, jack it up and check for play putting it in gear and turning the wheel, just rock it and see if there is any major movement. You cannot teach stupid people to do clever things
Post #29096 5th Apr 2010 11:23pm
CFB
After much investigation it turns out that the grating noise I could hear when the suspension was fully articulating turns out to be the rear tyres rubbing on the spring seats at the top. Rather odd as the alloys are O.E. Freestyle and the tyres are 265/75/16 which I have run before on a Defender with no issues.
Very strange but definitely the cause as I can see the shiny patch on the spring mount where it has rubbed and could see the tyre touching when I crawled underneath!! Andy
Post #29966 16th Apr 2010 3:42pm
TACK
Sets the mind at rest now you know what it is Thumbs Up
Post #29968 16th Apr 2010 3:50pm
CFB
In some respects yes but also can't understand why the tyres rub as this is a commonly fitted size, can only assume the offset of the Freestyle alloys is the problem.
Going to change for 285/75/16 soon so will probably go the modular steel route to avoid future problems. Andy
Post #29973 16th Apr 2010 4:08pm
TACK
I have the same size tyres and I have no issues yet, I have inspected underneath too to make sure. I too have steel modulars, so a cheapish option if you don't want to change 5 tyres Thumbs Up
Post #29974 16th Apr 2010 4:10pm
