Home > Maintenance & Modifications > Hand brake problems |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Another thought, would a sticking cable throw up symptoms like this?
9th Dec 2013 5:25pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5788 |
A sticking cable is common but can't see it producing the problem difference between driven, or being pushed. That would indicate more, as you say, towards the output flange altering its position.
Andy |
9th Dec 2013 6:28pm |
Ok, so I decided to have a look at my binding handbrake again today in order to chamfer the edges of the shoes a little more.
All sorted but it still binds.......but after a few test rolls I decided the handbrake was not the problem. If the gearbox is in reverse and I roll the car with the clutch pressed it binds. However, if I take it out of gear it rolls freely. When I put the transfer box in low range the binding is a lot worse, to the point you have to drive the vehicle in order to move it down the slope. It is an interval bind if that makes sense....bind...release...bind...release...etc...and all this ONLY when rolling backwards. There are no problems going forwards at all. On top of all this the gearbox chatters under load in 4th gear quite badly. When I put some weight on the gear stick with my hand, it stops. Recently, it has started to do this slightly in 3rd as well. This is obviously a gear/transfer box fault but can anyone help me narrow my search down a little? I have also got some fancy dan manual gearbox oil in that is very thin...I wonder if I should replace it with land rover recommended stuff to see whether it eases the situation. James |
16th Jan 2014 3:49pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4793 |
If you suspect a gearbox fault then maybe talk to Ashcroft transmissions, very knowledgable 2002 90 Td5 Station Wagon
16th Jan 2014 4:26pm |
