Home > Maintenance & Modifications > How do you charge your battery?
Pickles
I have a C Tek battery charger which specifically says it can charge with the battery in the car with leads connected etc, and I have the "easy connect" leads to make it easier.
However, reading the Puma's owner's handbook, it says that the battery has to be removed from the vehicle to be charged.
How do you guys charge your Puma's battery should the need arise?
Thanks, Pickles.
Post #299210 15th Jan 2014 9:51pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
The battery should be well-ventilated if you're charging from dead to full, leaving the battery in place is fine as long as you leave the seat and lid off. Thumbs Up
Post #299220 15th Jan 2014 10:14pm
Leenorthants
My alternator does a good job!
Post #299230 15th Jan 2014 10:41pm
JWL
As above, went to it this morning and discovered I'd left my heated mirrors on overnight, I was distracted by my annoying boys last night. Luckily I have them wired up to my auxillary battery and they had pulled it down to just under 9V. About an hours worth of driving throughout the day and everything is back to normal.
Post #299243 16th Jan 2014 12:08am
BigWheels
Long drives. Cool Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #299248 16th Jan 2014 12:35am
ericvv
Just put it on the C-tek with battery in place and without taking the seat or seatcover off. Connect the C-tek via the 12S plug, simple as that. A search will get this for instance....
http://www.defender2.net/forum/topic20342.html?highlight=ctek
And by the way, your battery box should be ventilated. If you look under your chassis, you will see a plactic ventilation pipe hanging from somewhere under the battery box. How do I know? Embarassed
http://www.defender2.net/forum/topic14789.html
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #299256 16th Jan 2014 5:04am
grafty99
Use my truck every day Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #299268 16th Jan 2014 7:37am
Eric
The vent pipe is actually from the battery itself, rather than the battery box. Just one more reason for using a genuine replacement battery when the need arises.
A CTEK charger should be fine charging the battery whilst the battery is in place and still connected. Some of the less intelligent old-fashioned "brute force and ignorance" chargers will make the battery gas, so disconnect and either remove from the vehicle or at least make sure that the vehicle is very well ventilated, also loosen or remove the caps on the cells of the battery. Do not underestimate the power of a hydrogen explosion!
Many years ago the battery on a large Volvo BM loading shovel exploded as I was starting the machine, and it was very spectacular! Fortunately no-one was nearby and I was protected by the vehicle, but bits of battery travelled about 30 yards and everything was drenched in acid. Not fun at all! On that occasion the battery wasn't on charge but had been recently, and the explosion seemed to have been initiated by ice which had formed on the battery, although to this day we're not quite sure exactly how it happened. A similar explosion inside a Defender doesn't bear thinking about - it would certainly cause very extensive damage to both the vehicle and the occupant and I imagine that both would be write-offs.
Post #299286 16th Jan 2014 9:42am
Just glad mine isn't left hand drive!
Post #299305 16th Jan 2014 11:46am
ericvv
Supacat, are you sure of that? You RH drivers run the risk of getting electrocuted by bad contacts in all the electric connections under your drivers seats. Lucas, etc. you know.... Whistle You never actually own a Defender. You merely look after it for the next generation.
Post #299323 16th Jan 2014 12:26pm
ZeDefender
Adding to that, if the battery(ies) beneath my seat explodes, I will be protected by the seat box cover, seat and my ample posterior, as I am ejected to safety (James Bond-style) through the ridiculously flimsy roof. From my parachute high above, I will be able to watch the rest of the vehicle slowly dissolve... Tell someone you love them today because life is short.
Post #299338 16th Jan 2014 12:58pm
Laurie
Why aren't they wired to the ign./aux. side so they go off with the key?
Post #299341 16th Jan 2014 1:19pm
JWL
Because I put them in, my decision to run them off a permanent live, but not off the primary battery so, as they did yesterday morning, when they get left on through my incompetence then I can still start and drive away, giving myself a kick up the rear to pay more attention.
Post #299344 16th Jan 2014 1:27pm
K9F
Due to the fact my Defender gets irregular use I am regularly topping up my battery with a charger which can be irksome. I am thinking of a permanent fit of one of these smaller discreet chargers and an aircraft grade electrical connector on the side of the seat box to connect it to the mains. The positive charging lead could also be hard wired through a fuse on my Blue Sea and the negative through a pushbutton illuminated switch to prevent backfeeding the charger when not in use. Connect the unit, push the button and away you go.
Unit.
http://uk.rs-online.com/web/p/battery-char...4E4F4E4526
12 Volt 20 Amp Carling Swith.
http://www.force4.co.uk/10278/Carling-Swit...-Line.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #299669 17th Jan 2014 5:16pm
ZeDefender
Good idea - and just fit a diode to prevent back-feeding perhaps? Tell someone you love them today because life is short.
Post #299673 17th Jan 2014 5:28pm
