Home > Maintenance & Modifications > Dashboard out. What (other) things to do? |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
dynamating? or some other extra sound barrier. My 109 thread
my youtube channel |
15th Jan 2014 11:45pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2762 |
The remote locking range improvement thing? Sure someone will know the tread on here detailing it Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
15th Jan 2014 11:56pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 |
Twin washer jets.
Anti corrosion treatment in any cavities. Any pictures? http://defender90xs.blogspot.co.uk/ |
16th Jan 2014 6:36am |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 |
I would be putting a bead of sikaflex or something along the back of the windscreen - bulkhead seal as is has to go sometime.
Rustproof everything. Dynamat. Extra Foam Have you thought about if you ever add additional lights or extras you could run a 5 core from the switch console and leave it coiled up behind the drivers speaker? William |
16th Jan 2014 9:26am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17536 |
While the dash is off you might want to make sure that the wiper rack and wheelboxes are properly lubricated, and also consider some anti-theft measures on the 10AS and OBDsocket.
16th Jan 2014 9:48am |
An extensive set of dash-out photos can be found here - you may need to scroll both back and forward through the pics. |
16th Jan 2014 9:52am |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
Gulp ! What brave clever chaps you are. I would so not attempt that !
16th Jan 2014 10:10am |
+1 for the twin washers
16th Jan 2014 11:52am |
Excellent - Thank you. No expense spared on the factory sound proofing. http://defender90xs.blogspot.co.uk/ |
16th Jan 2014 9:28pm |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
Wiper park switch, common and fiddly with dash in but easy with it out
17th Jan 2014 8:47pm |
