![]() | Home > Wheels & Tyres > Best 30mm Wheel Spacers, advice please ? |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
As the Subject, who supplies the best or does it make any difference ?
Thanks Guys CR |
What puddle? Member Since: 25 Oct 2013 Location: Reading Posts: 952 ![]() ![]() |
CR. I have just fitted mine. I looked at getting steel for the strength, but they are VERY heavy (25kgs!). I read up a lot and people swear by the strength of billet aluminium (whatever that means). I saw lots of silly prices, but finally got Bulldog ones for £110 from http://www.simonbbc.com/wheel-spacers/land...-set-of-4. Sent by overnight courier too - included in the price! Make sure you use a torque wrench set at 143 KGM. If you haven't got one, Screwfix sell one for £24. Now left.
......and make sure you tell your insurers as well.
Bows Member Since: 07 May 2012 Location: Wales Posts: 522 ![]() ![]() ![]() |
I bought mine from Uk Winchropes. Great service and great price
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
Another thumbs up for the Bulldog spacers.
I would advise you go with the hub centric design if you are using alloys to keep everything nicely aligned. |
Simon: Ah, now, it's getting interesting. I read up on this, but I'll bow to any superior knowledge here... I went for NON-hub centric solely because I'm using high quality (Overfinch) wheels and, more crucially, the original wheel nuts - which 'should' centralise the wheel on the spacer. If using nuts that come with alloy wheels then it might be better to use 'centric' spacers. Is that right? Apparently, using non-centric spacers can mean that there is still a very tiny movement. But (as I understand it) using the original (OEM) wheel nuts means that the wheel is centralised and won't move. If I'm wrong then I have just wasted £110 when I could have gone for hub-centric at £50 more
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8217 ![]() ![]() ![]() |
if you want an offset it would get some rims made up to suit what you want rather than run wheel spacers. 5 nuts less to come undone. Cheers
My knowledge is far from superior ![]() I do agree with you that the wheel nuts act to centralise the wheel. I may have overlooked this when purchasing. I like the idea of having the hub centric spacer as well as the wheel nuts though. I think I paid £20 more. I was worried that fitting spacers would give a wheel wobble but I don't have any and thats with mud terrains. I'm sure someone with more knowledge will be along shortly to correct us both ![]() |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 619 ![]() ![]() ![]() |
I also got the Bulldog ones from Defender Bits and I am very happy with them.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
Rakeway.
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
I bought Paddock's own, but have been told by the last garage I went to that the bolts which attatch them (to the wheels?) are short & any looseness is risky.
So I need longer bolts..... Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1986 ![]() ![]() ![]() |
Just looked on the rakeway website and they offer a 30mm and 40mm spacer any pros or cons with either size?
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Depends what wheels and tyres you plan on using really.
If running Boosts and 285s or 265s the 30mm spacers will keep the tyres in the arches but the 40mm will not, and to be legal you'll need to enlarge the flares. Narrower than 265 the 40mm spacers should be ok. It is unlikely that there'll be any significant performance, handling, or durability difference but I went for 30mm myself. |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
The ones I had on my Discovery 3 were Terrafirma 30mm, billet and were very good. No issues with their fitting and also you didn't have to get the wheels re balanced as i hear you sometimes do for the steel spacers.
http://www.terrafirma4x4.com/products_php.php?cat=116&grp=26 |
