Home > Maintenance & Modifications > Which bumper??
bear100
Which bumper??
Hi all, I want to replace my front bumper, what are my options! I will fit DRL's at done stage and have no intentions of fitting a winch, 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #298301 13th Jan 2014 12:19pm
K9F
There are loads out there and it really depends on how deep your pockets are. If it's heavy duty or OEM style heavy duty these are very good and are reasonably priced. Alternatively they also sell tubular too.
http://www.firstfour.co.uk/item/714342/def...ent-bumper
I've got the tapered one and it has given me several years of service with no degredation at all. To me it looks fine too but not to everyone's taste undoubtedly.
Alternatively go to Entreq and you can pay £680 for something that has exactly the same functionality. Shocked
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #298302 13th Jan 2014 12:24pm
Cheshire110
Just fit one of killer90s (CSK) heavy duty powder coated DRL bumpers. Thicker and much better protected than the standard one so less rust/chance of twisting it and denting the wing as you see happen to so many. Top quality DRLs pre-fitted too and comes with wiring/controller!
Cost me £180 delivered which is ludicrously good value and I can 100% vouch for the product. It's what landrover should've fitted!
Pics and info of mine here: http://www.defender2.net/forum/topic25621.html Cheers, David
Post #298303 13th Jan 2014 12:32pm
K9F
If you don't want to potentially compromise the strength and integrity of your bumper (should you not go for bumper mounted drls) you could consider these perhaps?
http://www.mobilecentre.co.uk/index.php?ma...cts_id=400 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #298366 13th Jan 2014 4:58pm
Devon 4x4 sell some good strong bumpers, I have a Defender HD bumper on one of my 110, the other has a FCX DRL bumper.
D44 bumper about £140
FCX with DRLs about £200
Both 5mm steel, stronger than the LR OEM ones.
Post #298392 13th Jan 2014 7:15pm
Cheshire110
couldn't find it before, here's killer's post about his HD DRL bumpers, and the forum price.
http://www.defender2.net/forum/topic22848.html
highly recommended if you're looking to put DRLs on in the future, may as well go the whole way and do it from the start (no cutting, bolting etc) Thumbs Up Cheers, David
Post #298404 13th Jan 2014 7:39pm
Killer90
Site Sponsor
Thumbs Up Cheers David, keep good stock of them aswell usually. I sold my last two last week but should have around 20 on the shelf again within the coming week Thumbs Up As david said, there 5mm thick h/d bumpers standard to look at, reinforced welds and the holes allow the lights to be flush fitted or set back within, spacers allow the lights to move if you would like to position them Thumbs Up hope that helps Mr. Green CSK Automotive
www.cskautomotive.co.uk
Post #298450 13th Jan 2014 8:44pm
A left field alternative:
Post #335711 4th Jun 2014 5:06pm
Very rustic. Rolling with laughter
Post #335713 4th Jun 2014 5:10pm
