Home > In Car Electronics > Removing Blanking Plate for Radio
Cuthbert
Quite a number of references to removing the blanking plate on the forum.
What's the definitive way to get it out cleanly without damaging the surrounding trim? It certainly seems to be a tight fit.
Post #297684 10th Jan 2014 10:42pm
I know what you mean, no one has come back and said how.
As far as I am aware as I have said originally removal is probably best from the rear. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #297699 10th Jan 2014 11:46pm
Cuthbert
No guru willing to share their expertise and experience? Really don't want to go in hard and possibly do more damage! Had a look and the panel seems to be in very tightly and with no room to get fingernails or a little leverage down the sides.
Post #298189 12th Jan 2014 8:29pm
mk1collector
I'll start by saying, I don't have a puma and have never worked on one, but I have worked on many vehicles over the years and have found the if you try to pry any trim out from the front it will inevitably damage the surrounding trim with the lever your using. From what I have read on here the centre part of the dash unscrews reasonably easily, so it would be best and safest to unscrew the whole centre dash section and push the blank out from behind. You will probably find a couple of push in tabs at the back that will release the blank.
Post #298193 12th Jan 2014 8:39pm
