Home > Technical > Speedo accuracy
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
Speedo accuracy
I have an old Land Rover 110, which is fitted with a 200tdi engine from a defender, I have now fitted a 1.22 transfer box from a discovery to replace the standard 1.6. ratio. The speedo cable is obviously linked to the gearbox therefore have the new transfer box ratios knocked the speedo out of calibration. The speedo is indicating a significantly slower speed to the speed indicated by a GPS but I do accept that this could be due to a number of reasons!! The vehicle is totally standard otherwise.
cheers
Post #297854 11th Jan 2014 6:27pm
Are you out about 2mph or a lot more? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #297857 11th Jan 2014 6:31pm
Bows
More, about 10mph out
Post #297868 11th Jan 2014 6:52pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Not to worry!
Once you have used GPS/Satnav to check what your speedo is reading at 30/40/50 etc. either just remember "true speed" or you could put a marker on your speedo. Whistle
My S2A is doing 30 mph when the speedo says 40 and 40 when it reads 52 and I have not got a ticket yet. I have always assumed it is due to the 31 x 10.5 x 15 tyres on it. 1970 Series 2A 88"
Post #297876 11th Jan 2014 7:00pm
Bows
Thanks Luke, establishing my speed isn't a problem, what I would like to achieve is having the speedo working as accurately as possible because I like to calculate mpg etc.
I am considering having it recalibrated, I am aware of the effect tyre size has on speedo readings but I was hoping to find out whether transfer box gearing also has an effect .
Post #297878 11th Jan 2014 7:07pm
I would imagine the transfer box ratio would have an effect though but I am no expert. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #297880 11th Jan 2014 7:10pm
lukev01
Bows, that makes perfect sense Thumbs Up
I am sad enough to calculate mpg on my Defender. Whistle
Even if I were to try on the S2A, I don't think I want to know what I really get from the 2286cc petrol. 1970 Series 2A 88"
Post #297890 11th Jan 2014 7:26pm
The speedo will be out because of the transfer box change. There is an interchangeable cog in the speedo drive that's calibrated for the different applications (Disco/Defender on two different tyre sizes). They are colour coded but I don't know, off hand, whether there's one that would suit your particular gear ratio/tyre size combination. Darren
Post #297906 11th Jan 2014 7:59pm
Bows
Thanks Anorak, I'll have to look into that, disco speedo settings will be thrown out by 7.50 16 tyres so it wont be straight forward.
Has anyone got any experience of that?
cheers
Post #297911 11th Jan 2014 8:07pm
ashtrans
Site Sponsor
If you use the speedo drive gear out of the old transfer case, then the speedo will stay true,
Dave Dave
Post #297973 11th Jan 2014 10:43pm
