![]() | Home > Technical > What grill fixings for my td5? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5850 ![]() ![]() |
Push fit fir tree, the same a ceiling but black. Six or eight of them, can't remember
Andy |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Thanks Landy Andy.
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
I thought they were 3 point pozi
Not on my Td5, three fir fix each side, and two fir fix at the bottom.
Andy Last edited by landy andy on 9th Jan 2014 9:30pm. Edited 1 time in total |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5922 ![]() ![]() ![]() |
On mine its Pozi drive screws (which are now stainless and covered in Copperslip) and these go into red plastic things. 1999 Defender TD5 110
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4799 ![]() ![]() ![]() |
+1 2002 90 Td5 Station Wagon
As mentioned here
http://www.defender2.net/forum/topic3630.html?highlight=grill And shown here http://www.defender2.net/forum/topic23721.html?highlight=grill Andy |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
I think everyone is right! Puma models with aircon grille=Firtrees, TD5 =Red plastic plug with Posi self tapper. Obviously over the years as grilles have been removed for whatever reason they might get put back on with different fixings! As the OP has said his grille has round holes I think he needs the Firtree fixings as the red plugs fit into a square hole. However he might find that a previous owner has drilled the original square hole oversize for a nut and bolt fixing so might be worth checking that before buying new fixings as you might end up having to use oversize bolts again if the grille has been modified. Slightly puzzled about the reference to the aircon grille however if the vehicle is a TD5 as they don`t have the extension nose that the Puma does even if it has aircon.
A td5 does have the extended grill for air con. The panel on mine is a good 10-15mm thick where the fastener goes through. The red plugs push fit into a single pressed aluminium sheet (as in my old 300tdi, obviously without air con).
Looks like I need some fir tree clips. Having looked at the links to other posts, are these more trouble than they are worth, as I have already bought some stainless nuts and bolts to replace the ones I drilled out? If, so, I may as well just use the nuts and bolts. |
TD5's definitely have the extended nose for aircon where appropriate. The grill on mine was originally fixed with fir trees, although I've replaced them with SS nuts and allen bolts. Darren
