Home > Maintenance & Modifications > Fuel Leak... Have you seen this before?
Page 1 of 3 123>
X4SKP
I noticed when cleaning my 90 that there appears to be some fuel run-off rinsed away from around the fuel filler area.
When I hose it down, particularly around the drainage area directly below the filler cap (1) this results in the apparent diesel rainbow film on the puddle below...(2,3).
I also noticed that this fuel wash off looked to stop after the initial 'flushing out',
(but I may be wrong here).
I have owned this 90 for 10 weeks now and have always filled it near enough to the top of the main filler pipe in order to check the MPG.
On inspection there looks to be no damage to the filler cap, main filler pipe, or tank. There is a slight cracking of the breather pipe where it swells over the plastic moulding (circled) but I dont believe this is all the way through, (this will be corrected in any event).
Has anyone seen this before? Any insight would be appreciated. Thanks.
My 90 is a 2010, 2.4 TDCI with 8K mileage.
Is this a Fuel Leak?
The Breather Pipe is showing some slight cracking...
Main Pipe and Tank look to be effectively as new... SKIP
Post #297125 9th Jan 2014 12:25am
Breather pipe is cracked a little on mine too but not leaking.
Doubt is so high up the pipe it's leaking unless your chucking it around bends and brimming the tank.
Or is this occurring when filling up?
My guess would be further down somewhere, perhaps pipe to tank. TheThunder Rolls🇬🇧🇺🇸
Post #297127 9th Jan 2014 12:43am
ericvv
You should not fill to near the top of the pipe. That may cause an overflow which just is a waste of fuel, and if with your very full tank you would put the truck in a warmer environment for some time fuel might expand some more and overflow might get worse. Always stop filling at first automatic click-off. As to the breather pipe issues, you can easily search for a dedicated link on here, but at times they do start leaking on the lower end as I know from my dealer.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #297132 9th Jan 2014 4:31am
Naks
Re: Fuel Leak... Have you seen this before?
Always fill up until the automatic pump shut off. --
Post #297140 9th Jan 2014 7:13am
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
As has been said, never overfill but you might have spilt a few drops of diesel on the plate that surrounds the filler cap when you were at the er, petrol station. The ridge between the plate and the vertical bodywork could then have trapped it.
Washing may have just rinsed it off. A little goes a very long way.
As someone who rides a motorbike, I am extremely keen that nobody puts diesel on the road (it's like liquid ice and kills people every year) but unless this persists or gets worse, I wouldn't worry.
Just maybe wipe the filler neck surround with a paper towel next time you fill up. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #297141 9th Jan 2014 7:54am
Caterham
doesn't that first photo show the fuel p**ing out?
mine had a fuel breather pipe that looked badly cracked / perished (replaced underwarranty) but never noticed it actually leaking and I always brim......I find the 'first click' a damn nuisance Very Happy
(how else would I keep getting 500 miles on a tankful Thumbs Up Mr. Green
I personally would be more concerned about the rear catching up with the front on a wet bend, motorcyclists who might be following and getting excess water / muck into your fuel tank.
good luck in resolving
ps. your chassis looks nice and clean as a result. Laughing
just noticed your main filler pipe......the jubilee clip near the tank appears to be resting on the chassis rail - is that right? I have a 110 so can't say for sure but mine is much higher up?
Post #297144 9th Jan 2014 8:27am
Macpaul
Actually, scrap that. I've just clicked on your first photo properly and there's more than a drop or two there. 2003 Td5 110 Hardtop
Post #297154 9th Jan 2014 9:13am
X4SKP
Thanks all, good points and noted.
I should have been more precise with my description, I do in fact stop at the second auto click when refuelling; having checked that it is actually full, (easy to know really that you are nearly there as we are all familiar with watching those 40+ litres get deposited). Occasionally on my previous Defender 1994-2013, 300 tdi 90 CSW, the fuelling auto-off feature would activate both on the commencement of filling, probably experiencing some sort of 'blow-back' but also at various points during filling. Slightly withdrawing the nozzle would often do the trick and stop this.
After 19 years owing the 300 tdi and knowing exactly what to expect this may be just learning the new vehicle. The exact configuration of body panels has changed around the filler cap and the current (and now last arrangement!) has taken the approach of allowing some / most of any water / fuel in this area to drain through to the inside surface of the rear body panel.
It is indeed possible that I let those all too often; last few dribbles run onto this area and set up a clinging oil residue to be washed away later. Needless to say I will be watching this very closely at my next fill, with a paper towel at hand.
Hello Macpaul, good point, I ride too and are acutely aware of this issue for bikers, it was part of the reason for posting this question. I have clocked up 250k in all four seasons, in the last 20 years. Oil residue at a set of lights has been my only issue with the ABS saving me now twice.
Hello Caterham, this is water not neat fuel running out having just rinsed it down. I will check also regarding the jubilee clip on the main pipe into the fuel tank, I noticed this too thinking it will be awkward to undo when required.
Time for a really close inspection... again thanks for initial thoughts. SKIP
Post #297158 9th Jan 2014 9:39am
Second auto click is OK, but don't put any more fuel in after that. If you 'brim' to the filler cap you will probably lose fuel through the atmospheric breather, and certainly will in the even of an increase in temperature.
The filler breather (small pipe to filler assembly) is designed so that when the pump auto clicks off there is still an expansion space in the tank.
The breather pipes (both the filler breather and the atmospheric breather) tend to perish, crack and split and will be doing this within about three years. It is worth replacing them since eventually you will have fuel egress and also potentially dirt and moisture ingress.
Post #297181 9th Jan 2014 12:16pm
X4SKP
Hello All, I thought I had an answer for this... but no.. now things have developed!
I would appreciate your thoughts / experience of this 'evidence'...
I had noticed that on removal of the Filler Cap I get a 'reasonable' amount of Diesel 'run-out'
which if I then shake the Cap gets to the point of 'a bit more than feels right', all the droplets seen
below are diesel! (New Cap on order)
Fuel Cap Diesel Drops...
On the recessed face of the 'Filler Bodywork' (below the Cap) there are two drain holes (left and right)
to allow rain water and in my case, more than a few drops of Diesel through to the inside wheel arch /
panel, where the Diesel either runs off or is 'stored' in the mud etc until it is washed out.
The wet 'run' here is Diesel after a more vigorous than usual 'shaking' of the Filler Cap
So whilst I have only managed a few hundred miles in this 90 since January, I have been careful in filling
stations not to add to my Dripping Cap problems. I have also not noticed any Diesel film / puddles when washing the 90, even placing a board underneath this area once, as we have just had 20 tons of new gravel
laid and the original photos showing a 'dirt drive' have gone.
Anyway even though this may be a small part of the original problem... things have moved on.
Main Plastic Tank Fuel Leak.
My guess at first glance in that Custom90steve's comment 'perhaps pipe to tank' and blackwolf suggesting that both filler and atmospheric breather pipes show signs of break down at or around 3 years are correct, (My 90 is a 2010) My 'breather pipe' at the Filler Cap end is slightly cracked, which you may just be able to see.
Filler Pipe 'cracking / break down'
My problem looks to be at the Tank end of these pipes, or possibly the Tank itself. The vehicle will get a
proper inspection this weekend to confirm, but any insight / experience of this would be appreciated.
Main Filler Pipe and Breather Pipe
The Breather Pipe in particular looks to be a tight and possibly torturous route through?
During this 'Fix' I will also reset the position of the main jubilee clip on the Filler Pipe as like Caterham also spotted it is resting on the chassis currently, which can only add stress to the neck of the Tank, this may actually be my problem but the 'Leakage Pattern' (above) suggests to me currently that the 'source' of the problem is higher up.
Thanks. SKIP
Post #321486 4th Apr 2014 8:53am
X4SKP
Hello All,
Just been reading through...
http://www.defender2.net/forum/topic22296.html
and it would seem highly likely that I am just going where 'many' have gone before,
is it really too difficult to make a Breather Pipe capable of lasting more than 3 years Question
might not be my problem, but is going to be my first 'look see'
happy to hear any comments. SKIP
Post #321578 4th Apr 2014 5:26pm
X4SKP
Replacing a leaking fuel breather pipe
Hello All,
I thought I would write up my fix, as it turned out to be less than straight forward.
To sum up...I have a 3 year old 2.4tdci 90 with a split fuel breather pipe, I have been filling the tank to 3/4 full to prevent further leaking whilst working out (and finding time) to fix this. Ive had the 90... 6 months now so didnt feel too worried that I needed to get the tools out...it must be about time and how difficult can this be Question
Fuel breather perished-cracked at the top... but clear evidence of a leak at the tank end of breather pipe.
(The wetness at the top end is plusgas in readiness to remove).
Plan A Replace with Standard LR Breather Pipe
I called my local dealer to check on a replacement...the conversation went something like this...
I need a fuel breather pipe for a 2.4 tdci Defender
Yes sir, let me check (sounds of the keyboard in the background)
whilst looking this up he asked, how old is your vehicle?
3 years, I replied
Yes, that would be about right,... we have just got 6 in, we fit 3 and sell 3 a month
ok...how much?
100...(how much Exclamation I checked this, 100, and decided there needs to be a Plan B)
Plan B Factored Part
80...
Plan C Trade Route
I managed to source a genuine LR OEM complete breather pipe for 60, but my issue, even at this price is do I want to do this every 3 years. I replaced the metal fuel tank on my 300tdi at 18 years and the rubber pipes were all still serviceable... has the puma breather pipe been wrongly specified Question
Plan D Improvise and Improve
The standard breather pipe is a 3/4 inch ID, 27mm OD, with a smaller T fitted breather pipe which looks to have a non-return valve (probably to prevent leaking in a roll over but not sure on this).
Some 10 years ago I refitted all diesel pipes on a family boat and used a very good marine source, they still look as new, and have been used in anger both in fresh and salt water environments, so I bought 1M of 3/4 inch 10bar pressure diesel fuel delivery hose (a hose that is designed to be fully submerged in diesel, some arent specified for this) and decided Ill make my own up. Cost 12 + vat + delivery = 16.
So get access to the breather pipe...its here the fun starts...
Raise the Defender off the ground (essential IMO)... release the main filler and breather pipes.
On mine the circlip on the main filler pipe needs to be punctured right on the end, breaking a thin membrane to reveal a screw head (this stops muck getting in and therefore corrosion, a good spec LR).
Remove the main filler pipe, Al anti crush element, siphon out tank and tape up. Obviously start this whole job with the fuel warning light on and with just a little diesel in the tank.
Remove anti-roll bar bolts, (rotate bar out of the way towards the diff) and remove X4 lower tank guard bolts. Remove X2 rear cross member tank guard nuts.
Edge the tank guard and tank forward to try and remove... I managed about 10-15mm then came to a halt...
The tank on my 90 is then right up against a floor spar. To get the tank out requires a forward movement of both the guard (and tank) of around 30mm. This takes the guard past the drop down sections of the chassis on which the tank guard sits, at this point the tank can then be lowered.
The tank guard has rear facing stud welded bolts that project 23mm through the cross member, when I finally got the guard off I measured these and they project around 28mm in total, so again you need even with a bit of twisting downwards thrown in (if possible) a forward movement of 25-30mm is required to remove the tank and guard.
The leading and rear overlapping elements of the tank guard require a straight forward movement (towards
the diff) of 30mm to clear the chassis...if all remains as standard. But straight forward it isnt.
Now it's at this point that you realise that on this 90 (and I would like to know if the 110 / 130 has a different arrangement), to get the tank out requires a significant bit of force to lever it out, (I mean really significant force) probably scuffing or semi-deforming the upper top corners of the tank in the process.
I even lifted the carpets in the rear and started counting rivets when considering removing the rear floor (if I went this route then a access hatch would appear before the floor went back in), possible but more mad than my emerging plan.
You also realise that probably the assembly of this originally at Land Rover (I would guess) was a tank and guard fitted to a rolling chassis prior to the body being assembled above. I would also guess that if you did get the guard and tank out, on refitting you would lap the guard on the outside of the chassis rather than attempt to reinstate it back to its original position. Has anyone done this (on a 90), it looks just impossible to me.
You also consider that Land Rover were probably keen to get the range for the Defender above 300 miles,
and so made the tank as large as possible, it does feel as though someone has got under there with a
balloon and all but filled the space available.
So my fix was to cut the guard out, removing just the M10 fixed nuts on the corresponding sections of the guard. Prior to doing this I marked out a NS and OS template for a replacement pair of aluminium brackets (plates) to make good the guard, this ensures the hole positions are correct.
Offending parts of the guard removed... and the guard and tank can drop and twist out relatively easily.
I left the tank in place initially and removed the guard first.
Tank guard repair (or improved modification as it will now be called) I used aircraft grade 3mm dural sheet,
but 3mm, standard Al sheet will be ok, (steel would be good too but always looking for a weight saving)
SS M5 screws and nylock nuts to fix it all together.
Finished tank guard, cleaned, keyed, etch primed and painted, satin black epoxy.
The breather pipe can be replaced without taking the tank out, but I wanted to check all tank seams were ok and its easier to work on when fully out, release fuel pipe retaining clip/s and X2 main fuel lines attachments on the top of the tank, these are easy push release connections. (well done LR). There is also a single electrical connection plug for the fuel gauge that is easy to unplug.
Before the tank was out I could see a significant split in the breather pipe, it coincides with the swelling on
the plastic tank breather insert, this pipe (IMO) clearly doesnt like this condition, and its the same at the other end. On further examination there were 2 other splits next to the small T pipe also on the swelling section on the inner plastic insert. The splits on the breather pipe at the tank end looked as though they had been achieved with a scalpel, the one shown is right through.
My replacement breather pipe, I will reuse the smaller T breather pipe...
The 1M length of new pipe was fractionally longer than 1M, so I cut 2 replacement sections for the breather pipe, this therefore reduced the cost by 50% with a backup stored for later use, (hopefully many years from now).
The SS standard breather pipe clips are a good design and can be reused...
I also placed a piece of 15mm neoprene (closed cell) sheeting on the base of the guard to raise the tank up
to near its original position as my guard will now sit below the chassis mounts not above, the mounts are around 6.5mm thick 2.5mm guard = around 4.0mm lower. The neoprene compresses to around 10mm when the tank is full, (I checked) the reason this is important is that the main outlet of the tank is close to the chassis when installed and so its important not to put this neck under stress. So I raised the tank by around 6mm overall as originally mine was very close at this point with the circlip used in exactly the wrong position an actually resting on the chassis.
New breather pipe assembled and tank + guard refitted to Defender.
The anti roll bar bolts I replaced with SS + larger washers and the replacement M10 bolts and nuts again with larger washers are used where the old bolts had been, there is good access above the guard to get spanner or socket in to tighten these M10s up. I reattached the original main filler and new breather pipes. Filled her up and checked for any obvious you still have a problem signs.
I will now keep an eye on this. The big issue (for me) was to get a better solution for the removal of the tank guard and therefore access to the tank, especially if this is a regular job with a life expectancy for a standard LR breather pipe (it would appear) of around 1000 days. I didnt want to feel ripped off for a replacement pipe either 60-100 might be justified if it lasts 6-10 years, but from what I think I know, I dont trust that it will.
Hopefully I will beat that, and at a significantly reduced cost Thumbs Up
My first job on a puma...a sign of things to come Question SKIP
Post #333222 24th May 2014 1:14pm
LR90XS2011
excellent write up thanks (however I,m hoping I don't need it ) DEFENDER 90 TDCI XS,
Post #333224 24th May 2014 1:36pm
spudfan
Ireland
Great stuff. If (When Big Cry ) mine needs done I'll print this off and give it to whoever is doing it. Mr. Green 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #333290 24th May 2014 6:06pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
Excellent write up, I have the leak for some time and no it's not 3 years, my puma 2.2 is only 1.5 years old. If I fill to the brim, about 200ml will leak onto the floor and I can see the top of the tank is wet, so I think this is the same problem I am having.
I just want to check, you have this pipe that comes out of the tank that is short, and connects to the t junction which has a J hook on it and follow by a long pipe. The J part is the breather right? And it does not leak? The leak is on the short piece? Where does the other long end connects to? Is this pipe where the fuel goes to the engine or there are other fuel lines? Sorry I have not got the time to look under yet.
Post #334767 31st May 2014 11:37am
Page 1 of 3 123>
