![]() | Home > Maintenance & Modifications > Let there be light |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
They look good
![]() Can I ask what make? Cost? Quality? Andy |
Beam shots are good fella
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Ł50 the pair, Only Chinese lamps, but full metal case and stainless fixings, more pics to follow.
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Interestingly I just bought 4 of the exact same off eBay!
Hopefully should arrive Monday, are they good? Any shots of what they light ahead up like? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
ade666 Member Since: 10 Mar 2013 Location: crewe Posts: 50 ![]() ![]() ![]() |
Been looking at these on the bay myself to use as rear work lights on my dc. Would love to see a pic david when you have them on. 110 double cab in belize green.
Few little mods here and there 300 tdi disco |
To be honest I imagined they would be a flood beam (50/60 deg) but looking at the advert more closely(as I should have done!) mine say 'spot beam'
No clue what a spot beam is? Like normal high beams? Oh well will have to see what they're like. If someone finds the exact same in 'work/flood' beam I'd be interested Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
I have been using a pair of the twin LED spots from the same manufacturer on my bike (BMW GS) since the summer and they are excellent.
The same lights are available from several suppliers (I use MTFANSCLUB) and are available in several configerations including 2, 4, 6, 8 12, 18, 24 and upto 96 LED's (probably others as well). They are not E-marked but as far as quality & performance goes they are unbeatable for the money. I am fitting an eight LED flood on the rear of the 90 as a work-light. I had held off ordering it until I had thoroughly tested the ones on the bike but they appear to be holding up just fine so fitting is imminent. My main concerns (apart from the light pattern) were failure of the LED's, water ingress and damage to the lense. In all cases my worries have been groundless so I am happy to purchase more lights. ONE LIFE, GET IT! |
Thanks for the good appraisal, hopefully mine will appear tomorrow so should be able to see for myself
![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 ![]() ![]() ![]() |
Litch
Does the LED flood you're fitting have a switch ? Thanks Gavin |
Mines in the cab, http://www.ebay.co.uk/itm/151180050009?ssP...1439.l2649
Any chance of some beam shots sometime? No worries if you're busy or can't
Tried last night bu my I phone is crap at night shots, they are more of. Flood than a pot, but def worth installing!
No worries. Glad to hear you mention flood as that was more what I wanted..
Only read the bit that said 'spot beam' after is bought! ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Steve R Member Since: 13 Jun 2012 Location: Leamington Spa & Walton-on-the-Naze Posts: 166 ![]() ![]() |
I'd also be interested in a few pics of them installed David. I'm considering trying a couple of these as rear worklamps for camping trips etc so am also more interested in a flood type beam pattern.
