Home > For Sale & Wanted > [Free] LED bulbs
excossack
[Free] LED bulbs
Purchased for the Defender but found them a bit too short for the standard interior light. The measure about 34/35mm long x 20/21mm wide
 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #296473 6th Jan 2014 10:12pm
Leenorthants
F
Hi, these may fit my light, can I take them?
Post #296479 6th Jan 2014 10:20pm
excossack
If you want them grab them unless you want to measure up first? 1999 Defender TD5 110
Regards
John M0VAZ
Post #296481 6th Jan 2014 10:21pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Second dibs please
Post #296483 6th Jan 2014 10:27pm
Those should be good. Thumbs Up KEEP CALM AND Drill ON
Post #296484 6th Jan 2014 10:28pm
excossack
Ok. Dibs accepted. 1999 Defender TD5 110
Regards
John M0VAZ
Post #296485 6th Jan 2014 10:31pm
Leenorthants
Re: F
They will fit, happy days,
cheers
Post #296487 6th Jan 2014 10:48pm
excossack
Great. PM me your address and will post them out. 1999 Defender TD5 110
Regards
John M0VAZ
Post #296489 6th Jan 2014 11:00pm
JWL
It's generally 42mm for interior lights, you could allways try dropping a blob of solder on each end to make up the difference.
Post #296496 6th Jan 2014 11:55pm
Above is correct but. Have 38/39mm in mine, a little smaller but the contacts can be bent a touch closer together yo egg a perfect fit.
Any smaller though and it's impossible.
The standard bulbs generate quite a bit of heat, draw a decent amount and can flatten the battery quickly if not careful.
Especially if there is two!
I've got all of my LEDs and the lot put together even two fixtures and all the rest of it put together only use about 0.5A - 0.8A
And about only 50mA for the rear just the light only, that's just 0.050A Laughing
So both sandbars bulbs were pulling about 2 - 2.2 A (estimated)
Now both pull around 0.8A combined.
If you only had LED fixtures such as these then the draw plummets and is about 0.2A which is nothing really.
Mr. Green KEEP CALM AND Drill ON
Post #296499 7th Jan 2014 12:44am
excossack
That's why these LEDs are on the 'Free' list cost they didn't fit! Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #296515 7th Jan 2014 8:01am
DAZ110
If these didn't go I'll have them. Thumbs Up
Post #296556 7th Jan 2014 1:13pm
excossack
Still waiting on a PM from Leenorthants for conformation of wanting the lights. 1999 Defender TD5 110
Regards
John M0VAZ
Post #296564 7th Jan 2014 1:59pm
excossack
Taken - thanks for the interest.
john 1999 Defender TD5 110
Regards
John M0VAZ
Post #296756 7th Jan 2014 10:55pm
excossack
Posted. 1999 Defender TD5 110
Regards
John M0VAZ
Post #297195 9th Jan 2014 1:59pm
