Home > Td5 > which oil? |
Don't know which oil but Landrover recommend servicing every 6k miles
5th Jan 2014 10:48pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
6k!
the service portfolio I got with the defender says 12k for the td5 or 12 months. I guess if I could afford it then every 6k but it will not have hard use (not all the time anyway ) so 12k it is. |
5th Jan 2014 10:57pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Castrol Magnatec 5w30 A1 spec, bout £20 for 4 litre in Cost-co,Tesco have it on offer for similar price sometimes. Pov.spec,ftw. 2006, 110,TD5.
6th Jan 2014 12:16am |
the Castrol oil does seem a good bet and its fully synthetic!
6th Jan 2014 7:20pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5864 |
I purchases 20l of Fuchs Titan XTR 5/30 from Opie oils. Plenty for a couple of oil changes and I also use in on the wifes Focus 1999 Defender TD5 110
6th Jan 2014 8:48pm |
Podrob Member Since: 20 May 2012 Location: Co Derry, N Ireland Posts: 31 |
Any A1, B1 semi or fully synthetic 5W30 or 5W40. If changing at 6000 miles use semi, if changing at 12,000 miles fully synthetic is better.
8th Jan 2014 10:36pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Also - change both oil filters... I never see the point in just changing one!
Any good quality 5w30 oil will suffice - fully synthetic is the better choice. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
8th Jan 2014 10:41pm |
Thanks all for advice.
Going to go for fully synthetic oil (probably Castrol Magnetic) and buy genuine service kit from somewhere such as Duckhams. Porny- the service kit does contain both filters |
10th Jan 2014 10:52am |
Tommo... I keep all filters in stock
OEM so man-hummel and mahle.. same as genuine, but in a different box. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
10th Jan 2014 11:04am |
Marky Boy Member Since: 25 Oct 2013 Location: Maidenhead Posts: 96 |
Hi all,
Quick question - can you mix synthetic and semi synthetic oils. My TD5 was serviced by a dealer and I would like to buy some for top ups. Therefore does it matter which one I buy ? The reason behind this is that I seem to remember with motorbikes a few years ago it was considered a no no to mix synthetics with minerals etc. Cheers |
21st Jan 2014 1:06pm |
To be honest I don't know but would guess keep to one or the other and not mix
21st Jan 2014 7:25pm |
RockJaw Member Since: 15 Oct 2013 Location: United States Posts: 317 |
Tommo, if it is any use to you, we have been using Defenders and Cruisers sine 1972 in both military and mining applications and i can tell you that the best results we always had has been with Amsoil - hands down the best results of every oil we have ever used.
For Defenders use the OEM LR filters and Amsoil 5W30 Series 3000 Heavy Duty Diesel Engine oil - for cold climates use 0W20. And no, you do not want to mix synthetic with natural oil - bad idea. ****CENSORED**** |
1st Feb 2014 9:48am |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
Unipart do a 20ltr 5w30 fully synthetic A5/B5 for about £48 plus VAT. (Fuch oil as far as I know).
I've used for circa 5 years on D3 and Defender. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
1st Feb 2014 2:25pm |
