![]() | Home > In Car Electronics > Wiring multiple speakers |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
It will work if a little unortadox
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
Cheers, I actually have a 4 channel output, but the front ones are already wired in. I suppose I could do it that way too! 1998 110 300Tdi White Hard Top
Definatly wire them seperate then
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20645 ![]() ![]() |
If you have more channel outputs use them, it allows you more adjustment and control from the HU alone.
Tapping in etc isn't normally the done thing as each speaker is meant to have its own designated channel. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
If I've understood correctly you want to run 4 speakers in parallel from the head unit. If so I wouldn't recommend it as I think that would be making the two channels run at 2 ohms which I don't think many (if any) head unit built in amps are supposed to do. Also I think the sound quality would be poor at best! If your head unit has RCA pre outs amps are cheap and easy to wire up and the front speakers could still be run from the head unit.
A nice 4 channel amp would do the trick nicely.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6143 ![]() ![]() ![]() |
I'd just use the 6x9's in the back, they're usually a pretty good speaker with mid and a little bit of bass.
Adding other speakers will "spread" the sound, but reduce the volume and quality, and as said, unless you mess around with series-parallel wiring (which would be difficult with just 2 speakers per channel anyway) you may overload the amp in the H/U |
Taking the single feeds back to the headunit will allow you to wire them in series, which then should bring it back to 4 ohms
Cheers guys, some things to think about, at least! 1998 110 300Tdi White Hard Top
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
Wire in a compact 4 channel amp under Driver seat yhen run the cables from that the the speakers this will distribute sound corrwctly. im currently and mega slowly isntalling the same setup to my 110 with an extra set of componants. All I need to do is buy yet morw cable and make the wooden trim panels for the rear Windows and rivnut them in
