![]() | Home > Puma (Tdci) > ABS modulator |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 ![]() |
mine has a on and off vibrating brake pedal. Our friends here in this forum advised me that the culprit is the ABS Modulator and had it replaced so far no more vibrating pedal now.
it is normal Cannonball,how is the Emerald isle today 2.4 90 XS
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 ![]() ![]() ![]() |
Unusually bright and sunny Grockle thanks! Just finished planting a few spuds. Just to clarify the point, should the grating noise be there at every start up? It has been conspicuous by its absence over the last three weeks so not sure if it means there is a problem now it does not occur.
