![]() | Home > Maintenance & Modifications > Blue sea products |
They are predominantly for marine applications, nevertheless they are top quality and there are Forum Sponsors that sell them. I and other forum members have used them for auxiliary supply of circuits. If you go through life with your head in the sand....all people will see is an ar5e!!
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Another vote from me have 2 aux fuse boxes and USB socket and they are brill!! 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6127 ![]() ![]() ![]() |
I've used them on other peoples trucks i've worked on... top quality stuff.
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2957 ![]() ![]() |
Nuff said
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Vote from on the twin USB and ciggie socket. 1999 Defender TD5 110
make sure you insist on blue sea when you order, there are some copies about but not the same quality or size ...
Yes, Bluesea products are top quality products.
Yes most of the Bluesea range was designed for marine applications, but things like the fuse boxes can be used in cars. If you are considering fuse boxes consider either the 6 way 5025, or 12 way 5026 which both have negative bus bars. These have a smaller footprint then other makes and are lower in height which can be useful if space is at a premium. Brendan |
