Home > In Car Electronics > Battery question
Page 2 of 2 <12
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
Would acf-50 be any good?
Post #294868 1st Jan 2014 1:47pm
excossack
I did give it a coating of Wurth battery grease a while ago but maybe its worn off. Is corrosion also a sign of a dying battery/cells ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #294890 1st Jan 2014 2:55pm
ericvv
A bit Off Topic , but still a question about greasing electrics...
For electric connections including lights connections, towing sockets, underhood relays like those for my fogs and DRLs, is spraying their contacts regularly with WD-40 the right thing to do? I am not sure anymore what to think about WD-40, some here like it, some not... I thought WD-40 has a water repellent effect, so guess it is a good thing for all what I mentioned above? That is what I occasionally do at present anyway...
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #294891 1st Jan 2014 3:04pm
VeeTee
Netherlands
WD-40 has a indeed water repellent effect (hence its name: it was the 40th attempt to create a water repellent formula.
For the towing socket and lights connections, I apply very copious amounts of acid free vaseline, as I learned from my very good Land Rover specialized mechanic. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #294893 1st Jan 2014 3:24pm
ericvv
Vincent, thanks for the history link. Never thought of wikipedia-ing this product. Embarassed
Reading all that, guess what I am doing is ok. I actually started using WD-40 for the towing sockets more than 2 years ago, after I had to use a trailer for the first time when the SVX was just 3 years old.... And I found that the inside of the 12N towing socket was entirely corroded and useless. Land Rover dealer replaced it still under warranty, and since then I am spraying inside of both the new 12N socket and the later installed 12S socket liberally with WD-40 every few weeks, certainly each time after a car wash. Both sockets remain like new doing this.
Post #294894 1st Jan 2014 3:41pm
munch90
guess it should be
but acf-50 £15 ish a can
proper battery spray £3.50 ish a can
Post #294895 1st Jan 2014 3:44pm
Lorryman100
The tow socket gets a monthly squirt of electrical contact cleaner on mine as does any electrical plug that I disconnect. Thumbs Up
Post #294913 1st Jan 2014 4:31pm
ericvv
Post #294915 1st Jan 2014 4:37pm
K9F
No WD40 is a water dispersant and light lubricator NOT a cleaner. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #294918 1st Jan 2014 4:47pm
excossack
Heavy duty battery from LR is £160 odd plus Vodka and Tonic 1999 Defender TD5 110
Regards
John M0VAZ
Post #295113 2nd Jan 2014 12:53pm
munch90
you can get the exide premium 1000ea 900cca 4yr warrantry off ebay £82 delivered !!!
Post #295114 2nd Jan 2014 1:02pm
ZeDefender
Some years ago a mechanic/friend told me not to overdo the cca as it requires thinner lead plates that can die faster in winter and if discharged too far. Admittedly, I always use deep-cycle batteries now, so I'm no expert... Tell someone you love them today because life is short.
Post #295119 2nd Jan 2014 1:29pm
jimbob7
Eric
WD40 is oil based which can create poor contact on sensitive switches,it also attracts dirt making contacts even worse,something I found out years ago when the throttle position sensor on mi Escort started playing up,told by a fitter to clean it with PROPER electrical contact cleaner and not WD, never had another problem after that (also never bought WD again either).So use contact cleaner and a dialectic grease (silicon) to water/dustproof the connectors.
I used to use WD40 on mi motorbikes to help keep the corrosion at bay,but it cooks on hot parts making everything look like a sh*ty frying pan,silicon spray doesn't cook,doesn't rot rubber,doesn't attract dust,lasts a lot longer and it's a lot better waterproofer than WD Thumbs Up
Back o/t; Halfords sell a 900 amp Yuasa battery fer £130 5 yr guarantee.
http://www.halfords.com/webapp/wcs/stores/...yId_165762 Pov.spec,ftw. 2006, 110,TD5.
Post #295333 3rd Jan 2014 12:41am
excossack
Eventually pulled my finger out and replaced the battery. Ended up with a Varta H3. 830CCA / 100ah from the local motor factors. So will see what the starting is like when cold.
It took a while to clean up the +ve terminal as it was covered in hard dried crusty stuff. When cleaned up, I covered the positive terminal in Vaseline and then smeared it over the top as well.
On fitting the battery, it meant my 2nd battery would not fit in the seat box, so this was relocated to the back of the Landy. 1999 Defender TD5 110
Regards
John M0VAZ
Post #297836 11th Jan 2014 5:59pm
Page 2 of 2 <12
