Home > In Car Electronics > Battery question
excossack
Battery question
My TD5 seemed to struggle to start the other day when cold. Got the battery checked at a local motor spares shop. The battery is labelled as a 650cca. When the battery test was done I noticed the + terminal was corroded (which might not help) but the CCA showed as 550cca, so I have lost 100cca's
So a combo of the corrosion & 100 lower cca's wont help.!
What is the correct spec battery for a 99' TD5 ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #294593 31st Dec 2013 3:51pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Get as big a one as you can fit in the box. Numax are very good.
Alternately, go to Costco and get a Bosch S5 for £50 or so, with 5 year guarantee. There'll be a leaflet telling which you should have.
Post #294623 31st Dec 2013 4:58pm
You want a genuine battery if possible. Thumbs Up This weather does take a bit more out of batteries to start, noticed a slight difference on mine even.
Genuine batteries last for a long time. No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #294627 31st Dec 2013 5:08pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
Delphi Freedom, 12V 110Ah, CCA 800A, Delphi part number 19001340, LR part number YGD100860 Thumbs Up
Post #294644 31st Dec 2013 5:41pm
excossack
Cheers. 800cca is a bit higher than what I have now! 1999 Defender TD5 110
Regards
John M0VAZ
Post #294658 31st Dec 2013 5:59pm
dorstsmith2
This genuine battery Delphi Freedom, 12V 110Ah, CCA 800A fitted in too my TD5 90 back in 2003 By LR Mr. Green Cool
Post #294664 31st Dec 2013 6:11pm
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
I have always found that a quick and simple method of comparing battery quality is the weight, the heavier the battery the more lead it has in it when comparing say a 110AH to another 110AH. There is little substitute for more lead, the more the better it will perform and the longer it will last. 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #294791 1st Jan 2014 9:08am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
+1 for Bosch at Costco. I have used these for years, brilliant batteries for the money, plus the warranty. I think its 110AH, 800CCA but can check later if you need the exact spec.
cheers
simon
Post #294796 1st Jan 2014 9:16am
excossack
Is the Bosch battery deal a limited thing at Costco? 1999 Defender TD5 110
Regards
John M0VAZ
Post #294811 1st Jan 2014 10:31am
couplands
I don't think so, I just buy as/when I needed them. Depending on the store, they may be in the tyre dept.
Simon
Post #294850 1st Jan 2014 12:46pm
excossack
Cheers.
So what causes the corrosion on the battery terminals? 1999 Defender TD5 110
Regards
John M0VAZ
Post #294851 1st Jan 2014 12:48pm
K9F
Dampness usually causing an elecrolytic battery type effect between battery post terminal and terminal connection. Coat with a liberal dob of vaseline. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #294860 1st Jan 2014 1:21pm
ericvv
Post #294862 1st Jan 2014 1:27pm
K9F
That'll do nicely. It'll stop any moisture and/or air getting to it. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #294863 1st Jan 2014 1:29pm
munch90
battery terminal spray is very good .. I use it on the battery , any electrical connection I touch on defender gets a spray .. outside sockets , towing sockets (spray it on wire connections to socket and in plug ) ,all light connections, relays sockets etc
never seen any corrosion on electric joint after using it
Post #294866 1st Jan 2014 1:40pm
