Home > In Car Electronics > Fitting Amp/Sub RCA & Power on cables
Bionicmunky
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Hi all,
Just to clarify - I am assuming the easiest way to get access to fit the RCA and Power-on cable is to remove the centre dash/console with the radio in place?
Or do I need to take out the radio first?
Thanks,
John
Post #294479 31st Dec 2013 8:31am
K9F
Depends what head unit you have and what route you're taking with the cables, if you can gain access via the passenger footwell quick-release access panel (same sort as your fusebox one) to route and connect the cable in. In this case you would only need to take the radio out and not the centre dash. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #294488 31st Dec 2013 8:48am
barbel jim
http://www.defender2.net/forum/topic16968....sh+removal
Thought this might be of some use to you Thumbs Up
Post #294490 31st Dec 2013 9:06am
Bionicmunky
It's the alpine one (my2013 Puma XS).
Any idea which removal keys I need from Halfrauds?
Cheers again
John
Post #294492 31st Dec 2013 9:08am
barbel jim
Post #294495 31st Dec 2013 9:17am
Bionicmunky
Thanks Jim Thumbs Up
Post #294496 31st Dec 2013 9:20am
No real need to remove the centre dash at all really, you should get all the access you need through the radio aperture and from underneath as K9F describes.
Thumbs Up No Guts, No Glory.
Post #294558 31st Dec 2013 1:46pm
