Home > Td5 > TD5 Running Lumpy
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
TD5 Running Lumpy
Hi All,
quick question.
drove to the shop today and engine running fine and smooth, come out the shop and engine is running lumpy mis fire like?
it pulls away but when it tries to get higher revs it feels like it splutters and has no go in it.
I have checked the red ecu plug and dry as a bone (had new loom last feb and AFM same time.
I have checked and it has oil
can't see/feel any delamination on the intercooler pipes
not over heating
no excessive smoke
no noticeable leaks form any where on engine
I'm now at a loss??
various threads I have read say could be turbo actuator? would this cause lumpy running?
if not what else could it be??
many thanks in advance 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #293986 29th Dec 2013 7:15pm
Leenorthants
Suggest you do what I did....
Call rac, the nice man comes out and plugs in the machine...
If air flow sensor fault comes up, buy a Siemens maf sensor for £90, replace it (5 mins tops), problem solved.
Post #293996 29th Dec 2013 7:44pm
Leenorthants
Or if not sensor, then may be fuel filter, the rac man should tell you what's wrong and cheaper than taking it to land rover!
Post #293997 29th Dec 2013 7:45pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Disconnect the MAF sensor and drive it,if misfire goes then replace MAF.
Changed mine recently due to intermittent power loss bought it From BAS (site sponser) quality part and quick delivery. 2005 Td5 90 XS
Steve
Post #294006 29th Dec 2013 8:22pm
pj2106
I've already disconnected maf and no change plan on cleaning out fuel filter on weds.
failing that i'll take it to work on sat and get them to check with diag machine 2008 110 2.4 XS Utility (Hagrid)
Post #294007 29th Dec 2013 8:26pm
Lou Sparts
Could be injector seals try running through the purge procedure before starting see if that improves it. 2005 Td5 90 XS
Steve
Post #294013 29th Dec 2013 8:45pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
It's worth checking the free movement of the turbo wastegate actuator (as OP mentioned). I've not suffered from this so have no personal experience but I seem to recall the symptoms are more likened a speed limiter ... might be wrong on that.
Other than the already mentioned things, MAF/Fuel Filter/Injectors, the only other thing that I can suggest may be worth doing is removing the MAP sensor (on inlet manifold) and giving that a clean up. They do get pretty gunked up, particularly if you still running with the EGR in situ. Jon - 110 td5 [sold]. Currently Defenderless.
Post #294070 29th Dec 2013 10:31pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Does it smoke? Mine did with same symptoms, new maf, etc etc, even checked wiring over transfer box in pouring rain (wires chafe, common misfire prob). Then mech pal disconnected egr valve( pulled off vacuum pipes, 20 secs work!) runs a dream...... Egr blanking kit ordered for mine!!
Hth
Alex
Post #294116 30th Dec 2013 12:11am
jonesie
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Corris Grey
Just had this problem and it was No1 injector........ Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy )
Porsche 997.2
790 Bonnie
Post #294230 30th Dec 2013 1:53pm
pj2106
well this afternoon I have replaced fuel filter and sender on bottom and it ran and started to clear after 20 seconds or so and then stopped and wont re start diagnosis the in tank pump is fubar no noise what so ever!!! Sad Sad Sad Sad Sad Sad 2008 110 2.4 XS Utility (Hagrid)
Post #294611 31st Dec 2013 4:28pm
Cold_n_Wet
Norway
ign on, quick stabs 5 on accelerator to start the airing process, it will tell you quickly if the pump runs or not.
If the MAF is fubar it will still run, but fuel consumption will be hi.
Have you checked the fuel pressure regulator, those have a habit of leaking too "Rafiki" 2007 110 STW - Rolling rebuild.
Post #294702 31st Dec 2013 8:02pm
pj2106
Already replaced maf and tried to bleed no life from pump going to check relays before replacing pump though 2008 110 2.4 XS Utility (Hagrid)
Post #294737 31st Dec 2013 9:56pm
pj2106
just a quick update replaced fuel pump today and now purring like a kitten again thanks for all your inputs
Paul 2008 110 2.4 XS Utility (Hagrid)
Post #298099 12th Jan 2014 4:01pm
