Home > Maintenance & Modifications > Windscreen rubber - Genuine or Britpart, Bearmach, etc?
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi,
I had a new screen fitted recently, but the old rubber was totally shot, so I bought a Bearmach replacement which was used by the National Windscreen fitter when he installed the new screen.
However the damn thing leaks like a sieve now, large pools of water in passenger footwell!!
So I have arranged for National to refit the screen on Saturday, but do I stick with the Bearmach seal or get a genuine one or look at other makes?
I guess I am concerned that refitting the Bearmach will not make any difference...
Post #294185 30th Dec 2013 11:57am
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Personally I would use a genuine rubber when refitting. My experience with using pattern rubber parts is that they tend to perish after a very short time so are a false economy. Having said that even with a genuine rubber it would normally require additional Silaflex type sealer applied between the glass and the rubber/rubber and windscreen frame to ensure a leak free fit! The Defender seal doesn`t have the normal spreader insert to help tighten the rubber to produce a good seal so needs a helping hand in the form of some sealer! Hope this helps! Smile
Post #294192 30th Dec 2013 12:12pm
dnorrishill
dondiddy: Thanks for the reply, I guess the followup question would be should National Windscreens use a sealant or do I try to seal it myself later?
Post #294199 30th Dec 2013 12:32pm
Genuine. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #294201 30th Dec 2013 12:40pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
The curse of the blue box strikes again.
Go genuine would be my advice. 2005 Td5 90 XS
Steve
Post #294203 30th Dec 2013 12:46pm
dondiddy
The windscreen company should use sealer. If they are fitting it they should be able to guarantee a leak free fit and should use sealer as necessary. Most modern screens are bonded in place now anyway so perhaps the fitter was unfamiliar with an old style rubber seal like the Defender and perhaps thought that it did not need any sealer! If you have the chance whilst the screen is out give the corners of the frame a good clean as corrosion starts there and ends up travelling out under the rubber and onto the part of the frame that you can see. The best option for removing the screen is to cut the rubber away with a stanley knife as the screens are so easy to break and most windscreen companies will ask you to accept responsibility for this before they start work!
Post #294210 30th Dec 2013 1:28pm
dnorrishill
dondiddy: OK thanks again for the info. I was not too sure about the fitter who installed the original screen TBH, he removed the old screen by smashing it with a crowbar leaving shards of glass all over the place. This seemed totally unnecessary as I had given him the new rubber and he could have cut the old one out...
I would hope that the fitter will accept responsibility as they installed the screen that now leaks, but lets see.
Also I ordered a genuine rubber from Guy Salmon for £89.76 - 4x the price of Bearmach, but if it stops the leaks then what the heck!!
Post #294214 30th Dec 2013 1:56pm
K9F
From four years ago.... Thumbs Up
K9F wrote:
I have had a period where I have unfortunately had to have two windscreens replaced within a short amount of time. Initially in severe downpours I too had water dripping from under the dashboard on the passenger side footwell. On the initial windscreen removal I was shocked to see exactly how much water and grime was sat in the windscreen channel on the outside of the vehicle. (With seal removed). The company that was fitting the replacement screen said it was a known corrosion hotspot on Defenders and that the windscreen and seal should be sealed to prevent both water ingress and corrosion particularily along the lower edge. No problems since!
Solved several members leaky woes.....
david110 wrote:
Problem sorted, just got my car back from the dealer, the windscreen had been leaking into the bulk head, dry feet Smile Very Happy
fekete wrote:
Just had my window re sealed, looks like it done the job... thanks to K9 Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #294224 30th Dec 2013 2:12pm
dondiddy
Looks like you will be finding shards of your old screen for years to come! Hopefully if it is the same fitter as last time he will use a bit more finesse when removing the screen this time round! He really needs to spend a lot of time cutting the rubber away so that as little strain as possible is put on the screen when he comes to remove it. Having said that he might just want to pump sealer into it and not remove it given the likelyhood of it breaking.
I fitted a heated screen to my Puma this time last year but took the whole windscreen frame off the Landrover so that I could ensure that the new screen didn`t get broken when trying to fit it. I also got the frame repainted as it had a couple of signs of corrosion in the bottom corners.I did manage to crack the old screen whilst removing it but I wanted to reuse the seal which was in good condition.I used Silaflex when installing the new screen and had no leaks afterwards. It was not all good news however. The 2 weeks that the Landrover sat outside without a screen meant that rainwater got in under the tarpaulin I had over it and ended up soaking behind the dash. End result. 1 drowned radio that I had to replace! Big Cry
Post #294251 30th Dec 2013 4:58pm
Litch
I have had my screens replaced several times over the years (more than one vehicle) and always fit a new seal as who knows how long it will be before it is touched again? Longest has been in place for about 7-years, all have been BP replacements and sealant has never been used.
Result = 0% leakage and no splitting over time. ONE LIFE, GET IT!
Post #294281 30th Dec 2013 6:08pm
dnorrishill
So, the replacement rubber from Paddocks (Bearmach) leaked like a sieve.
I got National Windscreen to come back last Saturday and they "attampted" to seal it by blobbing black gunk everywhere!!
I called them back again and they agreed to refit the screen with the genuine LR seal, which is happening right now. TBH the guy today seem to know his stuff, he is from a different branch and apparently does screen for Land Rovers UK in Bath.
Post #297425 10th Jan 2014 9:15am
dnorrishill
Also took the opportunity to inspect the top of the bulkhead and its perfect, no signs of corrosion Thumbs Up
Post #297429 10th Jan 2014 9:28am
