Home > Td5 > Injector wiring harness
Laurie
My TD5 recently became a TD4½ and then a TD3½.
Seemed like the dreaded oil in the wiring harness problem.
Diagnostics pointed at a couple of the injectors.
Injector harness plug undone - no sign of oil.
Changed harness anyway.
I'd totally forgotten how my engine used to run. The transformation was amazing!
I've done a few hundred miles since and the performance and mpg are just like it was when I first had it.
It's just that the drop in performance was so gradual (over 60K miles) that I'd not really noticed it.
Think I'll put a new one in every couple of years..........
Post #274669 17th Oct 2013 9:23pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Nice cheap fix Thumbs Up 2005 Td5 90 XS
Steve
Post #274671 17th Oct 2013 9:29pm
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
Just did mine. Took 45 minutes. Local specialist wanted £135 to do it!
Post #278857 2nd Nov 2013 5:36pm
Razler
United Kingdom 2002 Defender 90 Td5 HT Zambezi Silver
Thinking about ordering a injector loom, few questions..
Iv looked in the red Ecu plug and no signs of oil, does the oil travel down the injector loom then towards red plug on Ecu?
Will a new injector loom have a different design to stop this problem?
Where's the best place to purchase the loom from?
Cheers all
Post #293538 27th Dec 2013 11:35pm
Gareth
Laurie, can you be a bit more specific as to how the engine was running/sounded prior to your loom swap?
Mine feels like its not going as it should, and seems to have a regular misfire ie slightly down on one cylinder at mid range revs. Goes OK if you really boot it, but not as progressive as I think it should be.
I have already changed the MAF sensor, and checked the turbo actuator. No oil in my ecu. Only other possibility that I can think of is either injector loom, or egr. What do you reckon, is it similar to yours? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #293540 27th Dec 2013 11:53pm
Laurie
Basically it got very lumpy, like something had gone out of balance and a severe shortage of power.
Post #293545 28th Dec 2013 1:46am
