Home > Maintenance & Modifications > Instant gasket
ibexman
Instant gasket
Which one do you use
Post #293471 27th Dec 2013 6:28pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
HYLOMAR UNIVERSAL BLUE GASKET Thumbs Up or
stag wellseal jointing compound Thumbs Up
Post #293475 27th Dec 2013 6:41pm
K9F
Agree..... Thumbs Up
Use sparingly as can be a b45t4rd to seperate later. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #293486 27th Dec 2013 7:22pm
jst
RTV Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #293495 27th Dec 2013 8:14pm
munch90
hylomar can be bad if to much is used as it non setting and excess can come away from the joint inside and block oil pick up strainers ( I have seen this many times I am not guessing ! )
silicone or rtv (much the same thing really) don't tend to come away inside
I prefer rtv
well seal is good but only on well fitting machined surfaces and can fail after a few years of temprature changes
Post #293498 27th Dec 2013 8:28pm
For general purpose use, blue Hylomar. Follow the instructions and you'll have no trouble. If the WSM specifies RTV, then RTV it is.
Post #293534 27th Dec 2013 11:19pm
munch90
yes your right
but lots of people always use to much of any sealer and ive seen it knacker some very expensive race engines and auto boxes . and sealer hanging out of a joint looks untidy.
hylomar because it stays soft gets sucked in oil pick up mesh and stays there sucked into wire mesh blocking them . rtv drys so doesn't get stuck into things and tends to stay at the joint its sealing .
general rule is you only need to see the very smallest bead from any sealer pushed out of edge of the joint . if you can just see it pushing out when tightening then its done its the job .. MORE IS NOT BETTER
sorry if it sounds I am telling some people there job .. but for some diy people its advise that may help them.
Post #293566 28th Dec 2013 8:30am
Alex1976
I just use the RTV I buy from GSF car parts - comes in aerosol cans and seems to be good quality but not expensive.
Post #293785 28th Dec 2013 9:18pm
jonesie
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Corris Grey
Use RTV its what Airline Engineers use on Jet Engines......... Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy )
Porsche 997.2
790 Bonnie
Post #294227 30th Dec 2013 1:40pm
