![]() | Home > In Car Electronics > Alpine and Apple pairing issues |
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 ![]() ![]() ![]() |
i know a lad i twisted who has had the same issue with alpine and iphone4 ill make a call in the morning and find out how he solved it
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3483 ![]() ![]() ![]() |
True Gent, thanks 1951 80" S1 2.0
ChrisD90 Member Since: 14 Aug 2013 Location: Middle Earth Posts: 71 ![]() ![]() ![]() |
If you feel confident doing so it's worth checking and if necessary upgrading the head unit's bluetooth firmware to the latest version;
Update page: http://www.alpine.co.uk/support/bluetooth-...oup-2.html Update Guide: http://www.alpine.co.uk/fileadmin/PDF/supp...in7_EN.pdf Good luck ![]() Range Rover Evoque |
Bionicmunky Member Since: 15 Oct 2013 Location: High Wycombe - Buckinghamshire Posts: 108 ![]() ![]() ![]() |
I upgraded my firmware on day 1 - Everything works just fine on my iPhone 5
Shout if you want a hand - I'm in Wycombe so in your general area. JT |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20746 ![]() ![]() |
As mentioned probably firmware update needed, just follow on site instructions and you will be fine.
as i said i have checked with my twisted contact
check the paired devices memory in case that is full then as all the other posts ubdate firmware |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
Please be careful everyone... I 'upgraded my unit' and now I have no bluetooth at all.... Everything seemed to be ok but obviously something wasn't quite right... I can now no longer enter any of the bluetooth folders and can no longer get any connectivity...
Does anyone have any contacts in the Stirling area who can help? Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
Right I took the advice. Rather than firmware update, checked Bluetooth list of devices. It had 4 in it. Not sure if that was full so deleted them all and re searched for my iphone 4. Paired
![]() Thanks guys 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Excellent glad your sorted
