Home > Maintenance & Modifications > Old Man Emu shocks worth it? |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Like title says, is it worth while buying old man emu shocks? Im after a more comfy ride, everyday defender driving, nothing too extreme or anything too fast on the road, just looking for a better, maybe even softer ride on back roads and farm tracks. At the moment im running terrafirma shocks which where quite good to start with but after 2 years there nearly shot.
So whats the opinion? Thanks. Pete. |
21st Dec 2013 4:43pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Yes great improvement over std shocks
21st Dec 2013 6:58pm |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 |
Good ride but the rear shocks have a weakness in that the lower bush rings are known to sheer off!
You can also get the same shocks cheaper from Monroe but I can't remember the Monroe name. |
21st Dec 2013 7:18pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2626 |
OME is good, but bang for buck, you can't go wrong with Terrafirma or Koni --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
21st Dec 2013 7:25pm |
Mud_Plugger Member Since: 12 Sep 2013 Location: Blighty Posts: 10 |
If you read the OP, hes on Terrafirma now. They are now shot already. Thumbs up for OME
21st Dec 2013 8:03pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7981 |
OME get my vote. 6years the fronts have been on my truck cab, they are superb (+2s) its used mainly off road.
Trayback is running OME on the rear, which i changed to after the TF just didnt last 2mins. havea set of OMEs ready to go on the 110 when i get around to it. yes i think they are worth the money i have tried Koni, TF, King, OME, std, Bearmach, TJM over the years and OME win, in this instance, £££ for value, for me based on my experience. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
21st Dec 2013 8:24pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5642 |
OME ready to go on my new truck. Only other I would consider is Koni. Pay out once, learn via our mistakes.
Andy |
21st Dec 2013 10:47pm |
Well i managed to get the OME ones from flatdog cheaper than the Koni's so ive gone for them! Guess what i will be doing this afternoon.................
Pete. |
22nd Dec 2013 12:06pm |
You will not be sorry the OME shocks are superb. I had +5" OME shocks with Gwyn Lewis' suspension setup for years, actually just taken it off the 110. I have now got Koni Heavy tracks on with standard springs and ARBs and the ride is just fantastic. I rate the Konis as highly as the OMEs for sure. When you fit the shocks make sure you prime them before fitting: fully compress and extend a few times each.
Enjoy the ride. |
22nd Dec 2013 1:01pm |
Carlosbeldia Member Since: 13 Oct 2013 Location: Cartagena Posts: 43 |
If your car is going to work with big weights in bad roads, don't go OME. They lasted about 7 months in my car. After that time they were insanely shot, really crap stuff for me and a pair of Toyota owners I know here in Colombia. Off course they lasted LOTS of time more than Britpart std stuff (27 days) and little more than Monroe Adventure (5 months). Original LR shocks lasted 3 years, that's quality. I wanted the Koni's or Bilstein (Terrafirma are really weak options), but Paddock's didn't want to send them by air, so had to bring Britpart Cellular Dynamics....
23rd Dec 2013 2:41am |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
OME are yellow Monroe,s.
23rd Dec 2013 2:47am |
Got them fitted, seem a bit stiff at the moment but been told they will bed in a bit for the first few hundred miles, anybody else experienced this?
Pete. |
23rd Dec 2013 6:39pm |
Been out with them all day today and they are horrible!! I asked for some shocks for a softer more supple ride and they have done exactly the opposite! Its not a very firm ride and very very choppy! Looked on the OME web site and there for a 110 with over 300kg in the back. Does anybody know how i can go about returning them now they have been used, i did ring up and ask about them being so stiff and was told they need to be used to soften, but they havent at all, if anything there stiffer.
Pete. |
24th Dec 2013 9:16pm |
RustyM Member Since: 28 Oct 2013 Location: Africa/The Med Posts: 222 |
I have also found OME hard on the rear of a defender unless you carry a load with them, the only OME I would recommend is the steering damper!
I have tried many different makes over the years and end up back on LRO stock ones and then for some reason I repeat the cycle M 90 & Wolf 110 XS Previously owned SI SII SIIa SIII & Light weight (air portable) |
24th Dec 2013 9:30pm |
