Home > Td5 > Centre console illumination Td5 90
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Anyone have any idea how the switches on the centre console are lit up? Think I've done this before ages ago...just a little guidance needed before I dismantle.
Ta.
Post #292014 20th Dec 2013 6:43pm
bob neville
Is that how they are wired or actually illuminated ?
If the latter and they are the push type switches then they have a bulb that is inside the switch. The front cover does come off and I believe that gives access to the bulb/led. Not sure if it can be replaced though, it may be hard wired.
I can check over the weekend for you as I have a switch here in my spares box that I replaced the cover on a while back.
2013 Defender 90 CSW - sold
Post #292026 20th Dec 2013 7:02pm
grafty99
It is indeed a hard wired led, they can be changed ( thinking of white myself) except the hazard switch which has the worlds smallest incandescent bulb Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #292099 21st Dec 2013 2:16am
The hazard switch bulb can be changed too - there was a thread on here about it only last week. Darren
Post #292120 21st Dec 2013 8:12am
chipmunk
Thank you all, will take off front.......again!
Post #292157 21st Dec 2013 10:53am
PaulMc
The clear hazard switch bulb (STC1205) can be swapped for an orange bulb (STC1877), or a green bulb (STC1878).
The orange and green bulbs, used in D1/RRC and some Rover cars switches, are clear (3mm, wire-tailed) bulbs with a coloured 'condom' on them.
These Silicon Rubber 'condoms' can be bought in other colours -
http://stores.ebay.co.uk/dreamlixy2009/_i....=940834767
Alternatively, you can buy 3mm 'grain of wheat' bulbs in other colours, and fit them into the switch's bulb holder -
http://www.ebay.co.uk/itm/111023874400
You can also paint clear bulbs with thinned modeller's enamel paint, or nail varnish.
. Paul.
Post #292204 21st Dec 2013 3:46pm
