Home > Puma (Tdci) > Adding a second perimetric alarm sensor
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Has anyone, or does anyone, know if it is possible to add a second alarm sensor and how to wire it up to the alarm system.
I'm thinking of adding one for the pickup after some scrote decided to open the tailgate on my newly acquired Truckman top to have a peek. Fortunately, it's only the spare wheel in there at the mo which is locked.
Russ 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #291895 20th Dec 2013 10:54am
Porny
Site Sponsor
An additional door switch would be easy... so if any one opens the upper or lower tailgate it would trigger the alarm. You only need to run one wire for this - which can be picked up from in the roof harness or similar.
Also means you won't set the alarm off if you have dogs etc in the back.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #291900 20th Dec 2013 11:28am
rustyboxx
Thanks Ian, that is a much simpler idea and worth doing Thumbs Up
I had considered that but a switch alone wouldn't be enough if someone wanted to smash the glass and reach in to grab any goodies lying around.
However, keeping a dog, particularly a psychopathic breed with big teeth permanently in the pickup would be a great idea. Laughing 2015 90 XS CSW TDCi - Beautiful
Post #291926 20th Dec 2013 1:03pm
Fit both but in line switch the sensor. (Must be hidden perhaps in the cab)
That way up you can turn it off if need be. I have thought about it with my dogs but it's quite a little job cable routing and hiding everything. No Guts, No Glory.
Post #291928 20th Dec 2013 1:08pm
