Home > Tdi > Air intake |
Timo K Member Since: 23 Aug 2012 Location: Helsinki Posts: 171 |
I can imagine.
I recently installed a Mantec snorkel with a mushroom top, there was a very distinct difference to low rpm torque and throttle response, both were noticeably worse after the install. While installing the RAI, I (once again) couldn't help but wonder what on earth LR engineers thought of when designing the side intake tubing. The diameter is fine really, but the plastic scoop that's just behind the intake grille and front wing is maybe half the diameter of the rest of the system, combined with the fact that it's a double 90deg angle, it has to constrict the airflow quite a bit... When I have the time I'll just tilt the filter canister 90deg and run the flexi hose just between the washer bottle and heater, cut a hole on the side of the bonnet and run it through that to the stovepipe outside... I'm confident it'll flow as good (or even better) as stock with no snorkel. |
16th Dec 2013 9:26am |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
Timo
I think you are right. A direct tube to your snorkel will make a big difference. I am thinking about how I could do a custom air bin in place of the original that would give unrestricted airflow to the filter. Driving it again today really did notice how much more it just pulls as if it is just breathing easier. I have an ITG filter and now I am thinking if I had a less restrictive exhaust it would really start to make a difference. I am surprised that no one has ever done anthing to resolve this issue considering all the other tuning parts there are out there. |
16th Dec 2013 6:31pm |
You could maybe just use the air filter canister from a Range Rover Classic? It uses a similar filter in a similar housing, but has a trumpet intake on the front of the canister as opposed to the side inlet (under the filter canister) on the Defender.
17th Dec 2013 6:47pm |
