Home > Puma (Tdci) > 110 fuel filler query
22900013A
Is this normal?
I noticed today that the pipe leading to the tank is a bit twisted and doesn't sit flush with the outer rubber seal/ring. I have not noticed this before so can only assume that somehow the body and or tank have moved in relation to each other somehow. I see no reason why as I have not recently done any heavy off roading. My worry is that like this, diesel will leak out, in fact it was the drips down the side which alerted me to the problem. Does anyone have any advice? I tried moving the pipe underneath but everything seems pretty solid.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #286670 30th Nov 2013 11:24pm
Went out and checked mine and it's not showing any signs of moving like yours & not seem any photos of similar movement.
Have you got to the bottom of the cause yet?
Post #289500 11th Dec 2013 2:50pm
adamatdraycott
United Kingdom 2014 Defender 90 Puma 2.2 SW Corris Grey
I have never heard of the tank or the pipe to it moving.
On another note, is that a rust patch and a hole appearing in corner of the recess?
Surely not!?
Post #289507 11th Dec 2013 3:18pm
mk1collector
It'll be mud not rust as it's ally and if you look you'll find all those recesses have holes in each corner from factory Thumbs Up
Post #289522 11th Dec 2013 3:56pm
There is a plastic moulding which has the filler neck which is loosely secured to the body, and then two rubber hoses (large filler hose and a smaller filling breather hose) which run down to the tank.
It is most likely that the plastic bit isn't properly located in the body panel. It is unlikely to be serious, but you may be able to adjust it quite easily.
it won't affect the sealing of the tank, since the cap seals onto the metal extremity of the filler neck.
Post #289524 11th Dec 2013 4:09pm
22900013A
I was at E H Douglas the other day dropping off a gearbox for my IIA and mentioned this fuel filler issue to them, they said it was nothing to worry about. Looks a bit cack though and I have no idea how on earth it has happened... 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #289545 11th Dec 2013 5:53pm
"they said it was nothing to worry about" - does that mean it's a simple fix and they will sort it or just mean they can't be bothered to look at it?
Post #290035 13th Dec 2013 9:32am
22900013A
i took it as meaning nothing needed to be done, apparently the filler mouth is not attached to anything so it can move about. As long as diesel is not leaking I shan't worry too much, but will mention it when I go to the dealers next year. Warranty runs out in May so give it a good going over before then, I keeping a note of some leaks, paint cracks, rust etc. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #290162 13th Dec 2013 6:57pm
leeds
Could it be somebody has been heavy handed in trying to force the fuel cap off?
Not necessary you.
If not leaking fuel just wait until it is next at the dealers.
Brendan
Post #290164 13th Dec 2013 7:20pm
jst
or heavy handed with the pump handle? knocking the pump handle maybe when in the filler?
it is only a locator and doesnt seal anything.
try moving the pipe about where it sits in to the bottom rubber connector to correct the misalignment. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #290177 13th Dec 2013 8:05pm
22900013A
I have tried moving the pipe, no joy - it is quite solidly positioned. I can see no evidence of fuel leakage so I shan't worry too much. It may have happened when I ha to stretch the diesel pump a bit a couple of weeks back to full up but I don't see why, it wasn't exactly under huge pressure. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #290233 14th Dec 2013 8:19am
