![]() | Home > Puma (Tdci) > No ignition on cyl. 1 and OIL through exhaust.. |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
I wonder if you could have a broken valve spring? Could your mechanic do a compression check on no. 1? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
oil in exhaust could be turbo ,but if down 1 cyl for sure then could be broken piston quite common on transit engine and that made heavy knocking sound ..sometimes put down to running with dodgy injector spray pattern causing broken piston (not 100% if true ) but was reason we were given ..
have you had any smoking rough running etc before that could be down to injector fault or headgasket ? |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 ![]() ![]() ![]() |
Hi again - and thanks for replies. I fear it is the piston that is broken - a little while ago i experienced a lot of knocking when cold - used a little more 2 stroke and the engine almost went silent again - although not entirely - but I thought nothing more of it - until now
![]() Cylinderhead comes off tomorrow and then I will know for sure. Any problem in replacing a piston ? Anyone got an opinion about when to stop and look for a replacement engine? I mean engine has only covered 130.000 km. Best regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
Anyone got any experience with lovelandy? Found this
![]() Click image to enlarge 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Hiya
we have a fiat ducato in at work with 2.2. version of same engine, has done 160,000 miles on a 2010 model. Fault, rough running,eml on, smokes like a gooden. found fault code injector cyl 2 closed. Carry out comp test cyls 1,3,4 380 psi give or take cyl 2 100 psi remove head scored bores nackard piston suspect faulty injector may have over fuelled and over heated cylinder before ecu shut it down looks like new engine |
