Home > Puma (Tdci) > Puma clutch gearbox...drives me crazy! |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
Alanius in Zoersel: http://www.goudengids.be/alanius-zoersel-2980/
There's "the Rob" from Herentals, and GRX in Zottegem, but Alanius is the closest and the only one I had real dealings with (others I know from reputation). Give him my regards if you decide to use them! |
10th Dec 2013 2:02pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17307 |
The Puma gearbox and clutch do have issues, but when working should work every bit as well and probably better than the Td5 setup, so I am afraid you mechanic is misleading you. Generally the MT82 box has a better change than the R380 (which is really a bit of a dog), and most of the Puma issues are concerned either with the early clutch driven plates (the springs fail) or backlash in the driveline which causes a clunk and snatch on changing gear.
It does indeed sound as though your operating mechanism is not disengaging the clutch fully, as though it has air in it. Do you know that the job was done properly, and do you know the quality of parts fitted? If I needed a new clutch at the moment I woudl only get a main dealer, or a very trusted independent to do it (actually I'd probably do it myself) because I'd want to know exactly what quality of components had been fitted. My Puma has always had a nicer and better gearchange than my Td5 Disco2. |
10th Dec 2013 2:33pm |
easydeluxe Member Since: 18 Nov 2013 Location: antwerp Posts: 55 |
thx. I hope it gets sorted...
10th Dec 2013 2:36pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4636 |
My Land Rover replaced clutch is rattling too. I spoke to an independent and he said he would use a "Valeo" replacement.Considering that Land Rover replaced the origional clutch at two years of age, three years and 30,000 miles ago with an origional Land Rover part surely non genuine part can't be any worse. 1982 88" 2.25 diesel
10th Dec 2013 6:29pm |
mine got replaced by the kit from ashcroft, don't know what they use?
10th Dec 2013 6:43pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
Your pedal travel sounds like it could need bleeding mate. Check the clutc. Oil level it may have dropped. pedal travel, is normaly a fluid issue. Sometimes its the mechanical arm/bearing that hasnt been fitted correctly. 1st step check fluid 2nd step, bleed clutch pedal. nice easy job slave cylinder is very easy to access
10th Dec 2013 7:46pm |
Slave cyl is concentric bearing type ,On the puma (cylinder and bearing in one unit) and is inside bell housing so box out to change it .but it should have been changed at same time as clutch anyway .. I would give bleeding it a go .. Sometimes clutches can been a right pain to bleed even have to back bleed sometimes to get all air out
10th Dec 2013 8:01pm |
Phantom Member Since: 29 Jan 2013 Location: Isle of Wight Posts: 136 |
theorangebandit
10th Dec 2013 7:46pm Your pedal travel sounds like it could need bleeding mate. Check the clutc. Oil level it may have dropped. pedal travel, is normaly a fluid issue. Sometimes its the mechanical arm/bearing that hasnt been fitted correctly. 1st step check fluid 2nd step, bleed clutch pedal. nice easy job slave cylinder is very easy to access Not sure that's 100% true, the slave is behind the thrust bearing in the gearbox bell housing................. |
10th Dec 2013 8:03pm |
CARMARK2014 Member Since: 28 Dec 2013 Location: SHEFFIELD Posts: 57 |
My puma clutch as just been replaced at 39000 miles.
28th Dec 2013 11:16pm |
