Home > Technical > Rear end shunt to Defender and possible suspension damage |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Not seen the same damage...
But the 'engineers' are not engineers! It really annoy's me that they use that term. I'm sure some of them are quite clever... but others are a bit 'special'. I had a discussion with one that a customers vehicle should have the air condenser changed as it was bent. He disputed this and also inferred that I was lying - and that it didn't need changing. A strongly worded letter, photographs with circled bits in red so he could see them easily and adding all my letters after my name did the trick (and not just TIT)... lol. No apology, no dispute - but suddenly the claim got accepted. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
9th Dec 2013 1:15pm |
TRR Motorsport Member Since: 07 Oct 2010 Location: Leicestershire Posts: 115 |
Thanks Ian,
The claim assessor (i wont call him an engineer) in not so many words told me i was a liar the first time he looked at the 110 on my drive. he told me that the mis-alignment of the axle was an optical illusion because the mudflap was missing! I can see i need to pay for a 'Proper' engineer who understands pyshics to inspect and report on the damage. Is there anyone on the forum that can fulfill that function? "If it ain't sideways, you just ain't tryin'! |
9th Dec 2013 1:21pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5865 |
Would Land Rover have some jig data available? I.e the measurement of the centre of the axle to point x should xxx mm? 1999 Defender TD5 110
9th Dec 2013 1:26pm |
The bodyshop sent it to Sturgess in Leicester (Main dealer) on an instruction from the insurers for what they believed was a chassis jig check. instead they just did an alignment check which said what we all knew. that the rear axle is about 5mm out of alignment.
this isnt the issue though. the problem is that the 'vehicle inspector' will not accept that the damage was caused by this accident. I've owned the 110 since new and i know it has not been damaged before but i'm under the impression that the assessor thinks i'm trying it on. "If it ain't sideways, you just ain't tryin'! |
9th Dec 2013 1:32pm |
Ask your insurer for a senior assessor and make sure your there when the defender is checked over. Ask them how the brackets are supposed to have moved at another time as this is the only accident in the vehicle
9th Dec 2013 2:11pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
Lol. Class |
9th Dec 2013 6:33pm |
Do you have any photographs of the accident itself? You could always go to the insurance ombudsman with the issue and back it up with as much evidence as you can muster. Forget about mudslinging and innuendos with these to55 pots. Ratchet it up a level.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
9th Dec 2013 7:26pm |
Thanks Guys. I'm going to inspect it tomorrow so will take photos.
I like the idea of wanting to meet the assessor there and then asking how the damage was supposed to of happened if not during the accident. I'll keep you posted. needless to say Adrian Flux and Markerstudy (the insurer are not on my Christmas list. "If it ain't sideways, you just ain't tryin'! |
9th Dec 2013 7:47pm |
Shirty Carpet Member Since: 10 Nov 2013 Location: Essex Posts: 25 |
I'm insured with MarkerStudy through Adrian Flux, so will watch with interest!
I wish you well. (Admittedly my reasons are partly selfish!) |
9th Dec 2013 10:09pm |
I have experience (BAD I hasten to add) too of those underwriters.....The way I was treated as a customer was abysmal.
From some older threads.....One of them yours I note....
9th Dec 2013 10:11pm |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 661 |
Have you measured the distance between front and rear radius arm mounts on each side? It wasn't until I had a similar shunt to you with a. Astra hitting me up the rear that I noticed I had a 90" wheelbase on one side and about a ~91" on the other. On mine it clearly left the factory like that!
Cheers Steve |
9th Dec 2013 11:41pm |
Well after a hell of a lot of effort the 110 appeared briefly back on my drive this morning.
But only long enough for me to spot the chuffing great crease across the roof just behind the alpine window and a dent on the roof! looks like it's had something dropped across it or more likely its fit the underside of a 'Z' purlin on the underside of the workshop roof when it was on a ramp! Obviously i'm far from happy "If it ain't sideways, you just ain't tryin'! |
11th Dec 2013 1:21pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1792 |
Firstly well spotted!
Secondly have they fixed the bent suspension / brackets? Thirdly good luck Keith |
11th Dec 2013 9:23pm |
randallised Member Since: 30 Apr 2012 Location: Doolin Posts: 18 |
Hi I used to repair accident damaged vehicles on a jig, defenders included. If its more than 3mm out its accident damage to be sure. Car-o-liner do data sheets so you can measure any given point. Call into a bodyshop and get them to photocopy one for you. Then measure a known distance between two points against yours. Then get the insurance company to explain how this got bent otherwise. Goodluck.
18th Dec 2013 1:47pm |
