[For Sale] Barjo Dog Cage for RR Sport
Just in-case you know someone with a RR Sport.......
Having changed from a RR Sport to a Defender 90 (for my 4x4 at least ), I now have Barjo dog cage for sale, which was purpose made to perfectly fit the shape and dimensions of the boot of my old Sport.
It occupies the full depth (taking advantage of the "slope" both behind the rear seat and around the tailgate), and takes up about two thirds of the width.
Anyone who has looked around will know that Barjo make very high quality cages, and the bespoke ones (like this) start at around £480 - look them up on google.
I am looking for £225.
Because of size and weight it will need to be collected from South Yorkshire or delivered by courier at cost.
Dimensions and other info
As you can see, it has the usual "gate" at the rear, but also has an "escape gate" in-case of boot release failure, etc.
You can see from the images, that it can be set up with a "shelf" in position or this can be removed - I am told this is for anyone with a smaller dog who wants to give them some height in the cage.
The dimensions are;
At the base - 66 cm wide and 92 cm deep
It is 79 cm high
At the top it is 34 cm deep
Hope all this helps, but please let me know if you want any other dimensions or info - it is obviously designed to fit snuggly into the boot.
Thanks
9th Dec 2013 8:37pm
CEEGEE
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
