Home > Tdi > 300 tdi hard brake pedal |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Do you have vacuum at the servo ? 300 Tdi,s are well known for vacuum pump problems. 2005 Td5 90 XS
Steve |
9th Dec 2013 5:11pm |
Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98 |
i only got it home late last night, so not had chance how a proper diagnose as yet. just looking for common areas of fault to save me time. i do have a spare vacuum pump though.
9th Dec 2013 5:18pm |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
It could also be the non return valve on the servo, or one of the vac pipes may be damaged. Rhubarb and custard let fly with their secret weapon.
9th Dec 2013 5:56pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
Check where the servo is bolted to the master cylinder. around the 2 bolt areas you'll prob see 2 radial cracks where the servo dishes in, caused by the constant flexing. If so, an extreemly effective TEMP remedy is to cut some thinish strips of gaffer tape and stick over the cracks after cleaning the area. after all its a vacuum so it will be sucking the tape on, not trying to blow it off. worked for me for 9 months, only changed it because of the MOT man..
Also if it had an EGR fitted that has been removed, check the hose that comes out of the servo, it'll have a T peice with a thin tube coming off. make sure this thin tube is plugged, or you'll lose vacuum. |
9th Dec 2013 10:16pm |
