Home > Maintenance & Modifications > What's the best satin black paint for galv roof rack?
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Hi folks purchased a used galvanised roof rack and although I know it does not need painting I would like to freshen it up,
I want as tough a paint as possible that I can ideally spray from cans?
Any ideas much appreciated👍
Post #288425 7th Dec 2013 6:54pm
GUM97
You could perhaps use a black Stonechip on it, very tough? An engine to TDi for!
Post #288426 7th Dec 2013 6:56pm
When I painted my galvanised roof bars I used Hammerite Special Metal Primer followed by their satin black Smoothrite. It provides a nice finish which is generally pretty chip resistant, although it has struggled on the top surface where things like timber and bike racks have been dragged across the bars. I think most paint finishes, short of something exotic, would succumb to that sort of abuse, though.
 Darren
Post #288440 7th Dec 2013 7:38pm
I'd go for this:
http://www.ebay.co.uk/itm/Autotek-Professi...1e82a6b137
http://www.ebay.co.uk/itm/Black-Stone-Chip...3f2cbb8ec6
If you don't use acid etch primer you will have problems with flaking off and peeling. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #288441 7th Dec 2013 7:46pm
amondeggs
Thanks to all for your comments,
Thanks landroverAnorak that makes sense I'll go for that 👍
Post #288458 7th Dec 2013 8:53pm
K9F
A rack of that size would be quite labour intensive and costly I would imagine to buy the paint for. My Patriot was powder coated by the previous owner and the finish is very resilient. Also the usual issues that can occur between the assembly bolts and rails are erradicated as it was powder coated assembled.
Why not 'sound out' your local powder coaters you may be pleasantly surprised by the cost and not have the hassle yourself for a comparable price? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #288462 7th Dec 2013 9:00pm
amondeggs
Thanks kf9 another great idea I will find out before I purchase paint 👍
Post #288467 7th Dec 2013 9:16pm
Cuthbert
As Custom90steve has indicated - painting any steelwork that has been hot dipped zinc galvanised is going to give you problems if the correct undercoat/prep ain't up to spec.
I smile when I see painting contractors for local authorities and railway companies brush painting street furniture - 18 months later it is usually flaking off in large areas.
Post #288500 8th Dec 2013 12:01am
amondeggs
Thanks Cuthbert
I think I am going to find out the cost of powder coating first,
If this is too Expensive then having looked at the paint that customsteve recommended I think you are correct 👍
Now to find a good powder coating place in the midlands?
Post #288502 8th Dec 2013 12:11am
See that happen a lot, I've seen iron railings not primed too by people that don't know usually the more deprived areas / bridge ups.
On and around the estate I live on though things are done properly with red oxide primer.
Anyway back on topic. galv is a devil if it isn't primed. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #288503 8th Dec 2013 12:13am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
frost.co.uk do some excellent paint. give them a look, they do some quality o.e. finishes
Post #288684 8th Dec 2013 8:29pm
Terryt
Paint
When I did mine I used the hammerite primer and used a small gloss roller to put the paint on ,give a great finish,had it on a year now with no flaking etc
Terry
Post #288689 8th Dec 2013 8:46pm
I had my hannibal 110 rack blasted and powder coated for £100
Post #288850 9th Dec 2013 3:19pm
amondeggs
Managed to get a quote for powder coating as was £130 which I suppose not too bad Question
I think I'll go down the painting route as the roof rack will only be for occasional use.
I think I'll go for the acid etch primer and then stonechip recommended by customsteve , thanks again for advice Thumbs Up
Post #288987 9th Dec 2013 10:35pm
Welcome! I'll mention just in case you didn't know both the etch primer and stone chip you can get in packs cheaper and a larger amount. Just search "Autotek acid etch 4x" or similar on ebay.
Even if it isn't enough you can get more, it does last well. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #288994 9th Dec 2013 10:49pm
