Home > Maintenance & Modifications > Driver side air intake grill fell off |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 |
Hi there, There should be little pins on the grille that push into holes on the wing to hold it in place but they break easily and the grille falls off as a result. Sikaflex would be ideal for sticking it back on as there is no point in buying a new one as it would eventually fall off as well!
7th Dec 2013 6:10pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Thanks, this seems to cost only a little more than a tube of Sikaflex....
http://www.ebay.co.uk/itm/Land-rover-Defen...20dbe7da7e |
7th Dec 2013 6:20pm |
Yes! That would be a good excuse to buy a modified one!
7th Dec 2013 7:08pm |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 |
Buy a modified one mate, I have had 3 LR ones and now have a D44 one and much better
7th Dec 2013 7:31pm |
Seems a regular trend.....
Here's a solution. http://www.defender2.net/forum/topic20098.html?highlight=clips If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Dec 2013 8:03pm |
Like to idea of the c clips - might stick with the original grill
7th Dec 2013 9:46pm |
