![]() | Home > Puma (Tdci) > What are the differences between a hard top and a utility? |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
the main difference is that that HT has a center bulkhead inside. I assume we are talking 110 here.
The HT usually doesn't come with the alpine windows and rear headlining and side trim panels. You will still get the rear door trim. You will not get the plastic speaker trim in the rear, instead it will be a metal cover. You will usually not get the rear quater window, depending on the 'luck of the draw'. The defender has migrated, leaving the owner behind. |
I would have thought that the wheel boxes in the HT would be square, they are shaped in the USW.
The suspension option may be slightly different (HT my have heavy duty) There is trim in the back of the USW ( the same trim as a standard SW) Russell 2011MY 110 XS USW Black |
