Home > Maintenance & Modifications > Bolt on Bits : Indicators letting water in?
Hock
England 2014 Defender 110 Puma 2.2 XS CSW Java Black
I've bought a set of clear indicators from bolt on bits in leeds last month and noticed today that all four are half full of water! Big Cry
I've given them a call and they have said they're a standard land rover item (should have wipac written on them she said) so they cant do anything about it, only advice they can give is to dry them out and silicone seal the rear Rolling with laughter
Is this usually the case as i've not come across this issue before and Im not too happy about spending thirty odd quid on a set of lenses to later be told "oh yeah......they let water in......thats normal"
Post #287337 3rd Dec 2013 3:48pm
Mine are standard fit and moisture does get in. I'm not happy about it but not a lot I can do. I will go for LED soon though so hopefully will sort that.
There are some very very poor lights out there though and Genuine are pricey.
For a Puma clear side repeaters and just front indicators (XS clear) are getting on for £100.
Expensive yes, but if I had to change I would pay it, but LED will be for me. No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #287338 3rd Dec 2013 3:59pm
Martin
Site Admin
Sale of Goods Act - not fit for purpose.
Doesn't matter what excuse they come up with, could be a duff batch they've had or fake or anything else.
Don't be fobbed off Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #287339 3rd Dec 2013 4:01pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
There should be a foam gasket that goes between the lamp and the body to help keep water out. Thay do not come with the lamp however and need transfered from your old lights. Even then you will find that sometimes water gets into the lamp. I recently fitted a set of wipac lights to a friends 90(not bought from bolt on bits)and within a week or so condensation had formed in the lights. I know that some people have drilled a small drain hole in the bottom of the lamp to let excess water drain out! Neutral
Post #287342 3rd Dec 2013 4:06pm
Hock
I don't think there was another gasket around the lights, I'll have to check (if not the old ones still weren't full of water lol), they're saying they're a manufacturers spec part and therefore cant do anything about water ingress, other than blathering them with sealant Neutral .
I presume if they're left in 'as is' they will balls up the electrics? Big Cry
The other option she says is to buy their LED version, as this is rated as being water resistant, but I'd also need a relay as well as the four lamps, all in for 4 LEDs and relay would be another £90 Rolling Eyes
Post #287347 3rd Dec 2013 4:25pm
Would be fit and forget though! Wink I've heard good things about them, genuine is basically just the same pice but incandescent. No Guts, No Glory.
Post #287349 3rd Dec 2013 4:29pm
dondiddy
I have Bolt on Bits RDX led lamps and they are excellent! £119 for a set of 8 lamps and led flasher unit. When I went to fit mine to my 08 Puma I found that both rear stop/tail lamps had water in them and both male connectors on the back had rusted away due to water ingress.The RDX lights look standard but are very bright, well sealed and a very worthwhile upgrade. Doesn`t help you of course if you have just spent £30 on new lens! Crying or Very sad
Post #287352 3rd Dec 2013 4:48pm
Hock
I've dropped them a line to see if they'll put the cost of these units against an LED set as I don't want to be driving about with the risk of them blowing at any time Crying or Very sad ........... Fingers crossed they may be amenable
Post #287354 3rd Dec 2013 4:51pm
Wipac light units are notorious for leaking round the join between the lens and the body (it's usually here the water gets in, not through the back).
I have successfully sealed this join using polystyrene cement, as used for model kits, since the lights are made from ABS.
Post #287383 3rd Dec 2013 6:32pm
jimbob7
Yeap,my Wipacs leak behind the lens,can't remember if there is a drain hole on the bottom so make sure you fitted em right way up.You could use Captain Toll....this stuff, it get s excellent reviews.
http://www.amazon.co.uk/CAPTAIN-TOLLEYS-CR...B002UPK51C Pov.spec,ftw. 2006, 110,TD5.
Post #287543 4th Dec 2013 12:28am
grafty99
Even if they can be made watertight with sealer/glue etc a month old set of lights shouldn't leak! I would keep trying to get a replacement set Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #287564 4th Dec 2013 8:00am
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
I agree with Martin lights are not designed to work half full of water....not fit for purpose, demand a refund.
Your idea for an exchange on a set of their LED s is a compromise they should be happy to accept.
I've bought a set of their LEDs and am very satisfied with the service and the product.
You could of course twist their arm a little and advise of your participation on this forum and how after sales customer service is one of the regular topics discussed.
Not all publicity is good publicity.
DRW I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #288014 5th Dec 2013 8:38pm
Hock
I called them back and got the same response, they all let water in, even from the factory so cant do anything.
When I suggested they could put them against a set of LED's they said they would give me 50% of the purchase price back against LED as these lights are now 'used' and they cant do anything with them. And the LED's are, I quote 'more waterproof than the original items' Laughing I don't want to throw good money after bad so I'm just going to write them off, no more custom from me in the future I'm afraid! Evil or Very Mad
Post #288017 5th Dec 2013 8:45pm
A good product will get good reviews and sell well.
A poor quality product won't get good reviews and be avoided.
With either, we are a bit like sheep. If it's good we tend to copy others and purchase and use. If poor we tend follow the advice given of poor quality.
So indeed not all publicity is particularly anything with problems that do or can occur with the item. No Guts, No Glory.
Post #288018 5th Dec 2013 8:48pm
Splitpin
My led lights from there lasted just over 12 months then the insides rotted away.
Now I stick with cheap wipac and
normal bulbs!
Post #288027 5th Dec 2013 9:16pm
