![]() | Home > Td5 > High Low Transmission Switch |
If it will help me with this it would be nice, it is not anti stall as I am on the throttle first. http://www.youtube.com/watch?v=7Q9Fv2bU3pg Between 6:50 and 8:14. Just at the last bit, I go off the throttle and push the clutch and it stalls. My "friends" laugh about that because it happens more often. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 160 ![]() ![]() ![]() |
The housing for the Hi-lo switch can be ported over from the original Td5 1.4 transfer box to an older 1.2 transfer box. i'm sure it work. I've been there and done it. so it's just some bolts and it's off. then refit the other side and it's done. yea, it's a bit of work, but i had the 1.4 box in pieces when it was done. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
